Stock audio goes silent
Old Jan 24, 2015 | 10:10 AM
Ian69's Avatar
Default Stock audio goes silent
Having had the car for a week I have noticed this problem
The audio works fine for about 15 minutes then after that goes silent.
Still has power and display is on just completely silent
Is this the head unit or amp
I am going to upgrade the head unit in a few months just wondering if there was an easy fix for the time being
Previous owner had let the battery go flat so not sure if that has done something
Cheers
Old Jan 27, 2015 | 09:29 AM
millerzrule22's Avatar
Default Re: Stock audio goes silent
Sometimes mine cuts out for a second when I hit bumps, anyone know why?
Old Jan 27, 2015 | 09:33 AM
Loose plug?
Old Jan 27, 2015 | 09:55 AM
Get a set of removal tools for the head unit, pull it out and re-seat all the connectors.
If this is not a 'base' model, pull back the carpet on the passenger side and you will see a white metal frame held in place by 2 10 MM nuts.
Remove the nuts and fold it down, re-seat all the connectors on the large module ( this is the amp, the other one is the TCC if you have an automatic transmission )
Hope this helps.
usprb1976
Apr 4, 2024 04:57 PM
TerryR
Dec 13, 2019 03:27 PM
rmcdaniel12
Nov 4, 2015 04:08 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Sep 28, 2015 07:40 PM
