My OEM Siren Batteries Replacement Issue
Old Nov 10, 2019 | 01:09 AM
Thumbs up My OEM Siren Batteries Replacement Issue
... Deleted ...
Old Nov 10, 2019 | 01:30 AM
Default Re: My OEM Siren Batteries Replacement Issue
Good luck George, I have found that if there is ANY sign of leakage, the board is toast.
Old Nov 10, 2019 | 06:43 PM
Yep, board is toast, don't waste your time. Order a new one.
Old Nov 11, 2019 | 01:58 PM
Tbirdtony's Avatar
GraphiteGhost,
I agree with the other comments. The circuit board is toast. The circuit board is a multi-layer board. Without a good board to check your board against there is no way of knowing if circuit runs on either side of the board or circuit runs inside the board are good. There is a very good possibility that some circuit runs are completely gone. Throw it away and purchase a new siren. Keep the new batteries, maybe someone can use them.
Old Nov 11, 2019 | 02:07 PM
Tbirdtony's Avatar
GraphiteGhost,
Another comment: Those areas on the circuit board that had gotten hot and look black are another issue. The circuit board is made so that there is no conductivity between circuit runs. Conductivity is through the components mounted on the circuit board. Now the circuit board has burned areas which are basically carbon and carbon, like a resistor, conducts electricity. There really isn't anyway to fix this circuit board.
Old Nov 13, 2019 | 06:59 AM
RED DOG's Avatar
Talking Re: My OEM Siren Batteries Replacement Issue
Sorry but I agree with others that responded. You're wasting your time . . . Buy a new alarm siren . . . You want this part number . . . 2198203226 . . . The new unit will also provide audible "chirps" when you lock and unlock your Crossfire.
Look here: https://www.ebay.com/itm/Mercedes-Be...72.m2749.l2649
Old Nov 16, 2019 | 09:21 AM
Thanks, Bob. I saved this for later need.
Dennis E.
Old Nov 16, 2019 | 10:38 AM
Dennis E.
There are at least two sirens that chirp you can use, one with a stud as shown in the eBay thread and one that uses a bolt. CLICK
Old Nov 17, 2019 | 10:57 PM
... Deleted ...
Old Jan 4, 2020 | 05:40 PM
Default OEM Siren Batteries Replacement "UPDATE"
... Deleted ...
Old Jan 25, 2020 | 08:53 PM
... Deleted ...
Old Jan 25, 2020 | 10:40 PM
Make sticky please !!!!!
Old Jan 26, 2020 | 06:33 PM
... Deleted ...
Last edited by GraphiteGhost; Oct 6, 2021 at 06:51 PM. Reason: Added information about the battery lifespan
Old Mar 18, 2020 | 11:31 PM
... Deleted ...
Old Mar 19, 2020 | 12:16 AM
... Deleted ...
Old May 19, 2020 | 03:42 PM
mariontr's Avatar
I see that this number 171-82-053-26 reference in the How To in the index has been discontinued for the siren.
Old May 19, 2020 | 05:21 PM
Try 219 820 32 26 .
Old May 19, 2020 | 05:26 PM
mariontr's Avatar
Thanks
Old May 19, 2020 | 07:05 PM
mariontr's Avatar
Ordered and will be installed as soon as I get it. Hopefully, no issues in removing the other parts on the cowl and wipers.
Old May 19, 2020 | 10:53 PM
Johnny Versatile's Avatar
You may as well do the w/wiper escutcheon and cap fix while you have the cowl off. The siren replacement is straight forward.
