Electrical Wiring
Old Mar 11, 2021 | 12:30 AM
Dwight's Avatar
Default Electrical Wiring
Need to find a place or someone to wire this windrestrictor to brake or parking lights. Any suggestions in the north metro area of Mpls./St. Paul, Mn.
Currently works off acc plug in. Need to wire to either and/or brake lights or parking lights.
Old Mar 11, 2021 | 09:44 AM
Default Re: Electrical Wiring
So you want it to only light up when you apply the brakes?
Old Mar 11, 2021 | 09:50 AM
Dwight's Avatar
That is an option. Ideally it would be to constant power as I have a remote for the on/off and other settings.
Old Mar 11, 2021 | 10:05 AM
I wired mine to a switch under the dash, which is wired to battery. The wires run under the trim along the driver's side. I got power from the fuse box under the hood - there is a cool channel from the back of that fuse box into the cavity above the clutch/brake pedals. I picked up my ground from a screw under the dash as well.
Not sure who you can get up there,
Old Mar 11, 2021 | 10:43 AM
Dwight's Avatar
Thanks for the info. Since I have the auto trans, not sure if it would have said channel behind the fuse box. I would prefer to have a pro do the job so it looks and works as it should without issues. I will continue my search. Thanks again.
cvlieg
Feb 6, 2019 08:31 AM
tenarr
Oct 28, 2014 12:08 PM
bwagner
Jul 4, 2012 06:27 PM
austinboyette
Oct 26, 2011 05:44 PM
Darticus
Nov 17, 2009 03:52 PM
