Aftermarket amp... stock subs?
Old Sep 6, 2022 | 04:07 PM
JBRDH's Avatar
Default Aftermarket amp... stock subs?
Has anyone installed an aftermarket amp and managed to make the rear subs useable? (my OEM amp was replaced at some point... rear subs either need new surrounds...or replaced) Wondering how to wire up the OEM subs to an aftermarket amp,... knowing that the OEM amp also supplied power AND audio to each sub.... how would one deal with the power issue to the subs?
Old Sep 7, 2022 | 01:10 AM
UrbanE's Avatar
Default Re: Aftermarket amp... stock subs?
kicker has both subs and an amp that will work.
power for the subs (6-3/4” max size) comes from the amp
Old Sep 7, 2022 | 10:52 AM
JBRDH's Avatar
Mine came with a JL 4x100 amp... and stock subs... ordered a replacment pair... will see if they fit without modding the holders.
Old Sep 13, 2022 | 02:57 PM
nemiro's Avatar
@UrbanE do you have a part number for those Kicker subs?
Old Sep 13, 2022 | 03:11 PM
UrbanE's Avatar
I sure do, they are also listed on the back of subs in the image shown in previous thread.
Kicker
43CWRT672 (Discontinued)
I believe the part number has been changed to 48CWRT672Comp RT 6.75" 2 Ohm Subwoofer | KICKER®
I did a quick search and they appear to be the same dimensions but I would encourage you to dig into it before ordering. I would hate to guide you in the wrong direction.
(I have other images if required, just PM me)
Old Sep 14, 2022 | 11:50 AM
JBRDH's Avatar
noting that the oem subs needed new surrounds, I removed them... figured out that the oems were dual 2.25ohm coils...i decided to refoam them.... they are now powered by the JL amp that the original owner had installed... they sound pretty good...
Old Sep 14, 2022 | 01:11 PM
Sussudio's Avatar
Nemiro
Have you seen this series of subs from infinity? Looks like an interesting concept. I would’ve probably went with those had I not gone for the SKAR’s. https://www.sonicelectronix.com/item...oaAuSNEALw_wcB
Old Sep 14, 2022 | 02:37 PM
UrbanE's Avatar
Originally Posted by Sussudio
Nemiro
Good suggestion. I went and looked at them. First glance, these appear to be larger than the existing sub enclosure behind the seats. Might want to dig deeper to confirm before you select these
The depth adjustment to is interesting.
atd
Nov 15, 2017 11:06 AM
srtmodder
Jul 7, 2014 08:56 PM
AlexRMC92
Aug 31, 2012 05:48 PM
sive81364
Aug 1, 2011 08:30 PM
Romio
May 17, 2007 01:07 AM
