Battery Draining
Old May 15, 2023 | 11:14 AM
varikyno's Avatar
Default Battery Draining
Hello, First time posting...so I was riding in a great sunny day. When I stopped and went inside a sudden downpour appeared and I did not have my top up. Long story short...inside was drenched. After this my battery would have a phantom drain and I would have to jump-start it. I narrowed the drain down to the radio and I pulled out the radio and the battery no longer drains overnight. My question is, since I removed the stereo and there no longer is a drain, can I correctly assume there is an issue in the radio, and by replacing the radio with a new one all will be well? Sorry I am not a mechanic or electrician, I am just using the power of deductions. Anything else I should be looking at? Thanks
Old May 15, 2023 | 11:26 AM
Default Re: Battery Draining
The issue could also be the amp, under the floor on the passenger side. I would at least check under there first.
texas t
Feb 4, 2014 09:23 PM
Towncrier
Nov 16, 2011 07:21 AM
billvp
Feb 18, 2010 04:40 PM
boom182
Mar 15, 2009 04:14 PM
Chris Newman
Nov 3, 2007 01:32 PM
