Problem with the turn signal switch
Old Feb 26, 2026 | 11:36 AM
Myopic's Avatar
Question Problem with the turn signal switch
This time, I'm having a problem with the turn signal switch located on the left side of the steering wheel. I have to press the stalk up hard for the right turn signal to work.
I've determined the part number is: 5098519AA.
Unfortunately, this new part is unavailable in Poland. I don't want to spend money on a used one, as it might soon have the same problem.
There are several listings for a new one on eBay, but the price is very high.
Therefore, I'd like to ask if anyone knows if it's possible to disassemble this stalk and rebuild it, i.e., clean and bend the internal contacts.
Have any of you ever done something like this in this car?
Old Feb 26, 2026 | 12:48 PM
Default Re: Problem with the turn signal switch
Reference post #2,
https://www.crossfireforum.org/forum...placement.html
Old Feb 26, 2026 | 12:54 PM
exparamedic's Avatar
Hope this helps.
Jim
Old Feb 26, 2026 | 02:54 PM
Myopic's Avatar
@ZERACER @exparamedic Thank you.
I am going to show it to my mechanic.
Old Feb 28, 2026 | 03:49 PM
zip439's Avatar
Here is a switch ($21.00) located in Germany. Ask the seller what he would ship it to you for Turn Signal Same switch that is in the Crossfire.
Old Mar 1, 2026 | 12:04 AM
Myopic's Avatar
@zip439 Thank you, but as I mentioned earlier, I don't want to spend money on a used switch.
I've already made an appointment with my mechanic and showed him the above video and the documentation.
The mechanic said he'll rebuild the turn signal switch and also replace the seat control relay, as I mentioned in this thread:
https://www.crossfireforum.org/forum...justments.html
These two repairs are expected to cost up to $140.
Old Mar 10, 2026 | 12:56 AM
Redge's Avatar
I had the same problem and blew some electrical contact cleaner in the crevices surrounding this area. Based on the video above I knew the issue was buildup on the contact points. I had already purchased a used switch and disassembled it to clean it so that helped me know how I could best insert the spray nozzle straw. An avionics friend of mine made the suggestion to try this. It does sometime still not respond perfectly but it's so much better. Who knows? Maybe you'll have complete repair with this hack. It's definitely a low cost option to try beforehand if you haven't already replaced it.
Also I suggest putting the switch in various positions during the spraying to get the best chance at accessing these contacts. I believe I had the car battery detached and let it sit for a several days after as well.
Old Mar 10, 2026 | 09:19 AM
NeedsWings's Avatar
new are discontinued, if you found new old stock buy it ASAP
Old Mar 13, 2026 | 04:54 PM
Myopic's Avatar
Today my mechanic rebuilt the turn signal switch and replaced the seat control relay.
Old Mar 15, 2026 | 12:42 AM
Very nice!
Old Apr 14, 2026 | 12:10 PM
Myopic's Avatar
I have a request.
Since the mounting brackets have come loose, I'm looking for a plastic cover (possibly a used one) that covers the steering column and electrical components above the driver's feet.
It was unscrewed and lowered during the work described in this thread; it's also visible in the photo above.
Since I don't know the English name for this component, I don't know how to search for it on eBay, for example.
Can you help?
Old Apr 14, 2026 | 12:43 PM
I think this is what you are looking for. Use this for your search.
CHRYSLER CROSSFIRE KNEE BOLSTER REPLACEMENT
Ensure that it is for a left hand drive car which I think your car is by the pictures.
Several are available on EBay in North America but that probable won't help you with shipping charges so high.
Jim
Old Apr 14, 2026 | 01:31 PM
Myopic's Avatar
I found that probably this MB item number is A 170 680 07 87:
https://www.ebay.pl/itm/298223382716
Tomorrow I will try to find this item in MB shops in Poland.
I'm also considering welding this plastic cover - the upper right handle that holds the cover in place has broken off.
I also found the MB number A 170 683 03 26 of this item:
https://www.ebay.pl/itm/206196009798
Old Apr 15, 2026 | 07:17 AM
Myopic's Avatar
I received a quote for these two parts from the MB store: $1,060!
But unfortunately, Mercedes no longer sells them.
So, I'm left with repairing these two parts by welding plastic.
Old Apr 15, 2026 | 11:40 AM
Myopic's Avatar
D16
Mar 8, 2018 09:39 AM
jwaz16
Sep 13, 2017 10:50 AM
Bob B
Mar 23, 2015 02:52 PM
Bolisg
Aug 13, 2012 07:56 PM
stevewiz
Feb 28, 2012 01:31 PM
