Australia Serving Australia.
spare wheel
Old Nov 19, 2014 | 05:46 AM
saltiga's Avatar
Default spare wheel
Hello all, has anyone found a space saver wheel that would fit the crossfire, I am to believe there is a vw space saver that will fit? Also if the tyre diameter is different would this revolution rate effect the traction control or the esp./abs braking/ any one have any clues?? Saltiga
Old Nov 19, 2014 | 08:03 AM
DTMenace's Avatar
Default Re: spare wheel
saltiga
The attached thread is a discussion from a few years ago about a space saver tire as a spare. I purchased one several years ago, but never used it as of this date. Since it is a steel wheel, shorter wheel studs must be used, cannot use the existing lugs that came with the car. I am not aware if a VW spare will fit, based upon the brake calipers, you may want to check. I do believe the lug pattern is 5X112 on the VW, so it should fit, since our pattern is the same.
Good luck,
Dennis
DTMenace
https://www.crossfireforum.org/forum...crossfire.html
TerryR
Dec 13, 2019 03:27 PM
Darryl Camisa
Oct 7, 2015 07:10 AM
o55ie18
Oct 5, 2015 05:50 PM
Oct 1, 2015 01:42 AM
Mackel
Sep 29, 2015 02:41 PM
