Fuel Door Problem
Old May 1, 2006 | 12:09 PM
jayf's Avatar
Default Fuel Door Problem
After filling up and returning home, I noticed that my fuel door was open. After trying to shut it (I know about the lock pin) I realized that the spring type mechanism that holds the door closed was not working properly. If I push the door shut it will not sit flush with the body (the car was unlocked so the lock pin being closed is not the problem).
I will be taking the car into the dealer to get the problem fixed but I was wondering if anyone had a solution or similar experience?
Old May 1, 2006 | 09:10 PM
rpr1bob's Avatar
Lightbulb Re: Fuel Door Problem
Same thing on mine. 2 times in the last year. They keep fixing it. It must be a potential problem for all of us.
Bob San Diego, Ca.
Old May 1, 2006 | 11:14 PM
jpristel's Avatar
Default Re: Fuel Door Problem
Mine was doing that too, as it turns out, I just had a single twist in the rubber strip that connects the fuel cap to the fuel door. I couldn't even tell that it was twisted by looking at it, but by twisting it a full turn one way or the other it closed perfectly again. Worst case scenario, just cut that little strip off.
Old May 2, 2006 | 01:56 PM
jayf's Avatar
Thank you both for the replys. I am still at my college appartment and will be moving back home Wednesday. I will check if the problem is as jpristel stated, and hopefully it is as then I will not need to go back to the dealer since its always a hastle. If that is not the solution I will be heading to the dealer.
Old May 3, 2006 | 12:35 AM
rpr1bob's Avatar
Lightbulb Re: Fuel Door Problem corrected
Fuel door fixed.
Thanks Jeff! It was the cord twisted. I untwisted and the fuel door works fine. I bet that is what the problem the last 2 times.
Bob San Diego, CA.
Old May 3, 2006 | 09:25 PM
KalaMan's Avatar
Cord was twisted on mine too. Same Problem... Simple Fix.
Old May 4, 2006 | 12:03 AM
jpristel's Avatar
Good deal, glad I could help.
Old May 5, 2006 | 10:25 AM
crzy kat's Avatar
Had the same problem and it corrected itself before I took it in.
Old Oct 17, 2007 | 10:44 PM
jmlasker's Avatar
Like the others, had this very annoying problem as well. Learned from this forum how to correct it by untwisting the gas cap tether.
No problemo.
Old Dec 5, 2007 | 10:43 AM
sparks81's Avatar
I noticed the same problem on Sunday when I was filling up. I was starting to get concerned about it and decided to have another look. I guess when I take off the cap, I twist it unintentionally, kinda like the phone cord. A couple of twists and viola! problem solved.
Old Dec 5, 2007 | 05:32 PM
+fireamx's Avatar
No need to cut it, more than likely it will eventually break, mine did.
Old Dec 5, 2007 | 05:38 PM
Iamfink2's Avatar
Mine just about to break also just hanging by a thread.
BrenLW
Aug 5, 2015 04:53 AM
55chevy
Jul 20, 2015 03:08 PM
crymar
Jul 17, 2015 08:46 AM
66L72M21
Jul 15, 2015 04:23 PM
ja.nko
Jul 10, 2015 03:21 PM
