rear window antenna replacement
Re: rear window antenna replacement
Originally Posted by HDDP
FYI the only wires running to the rear window are for the defroster, wing motor and upper brake light. I have no idea where the antenna would be...
Check the wiring schematic in the repair manual.
I read a post here that stated, the antenna was located in the rear window of the coupe model. The reason I asked the question was because the radio reception for am is so bad for the two talk radio stations I like. I live in Boulder and the stations are located in Denver, they come in great on my other cars. I had the radio replaced with the new version and same problem. I read that the antenna might be the problem. Any ideas?
Tom
Originally Posted by tenacioustommy
Hello,
Tom
Tom
I took my car to an audio specialist (had to wait 3 weeks for an appointment) and he told me that the antenna was to short and that was the problem with the poor reception on the AM stations. He disconnected the antenna from the rear window and added a coiled length of antenna wire which he laid under the plastic covering on the inside of the window cover. This fixed the problem, hopes this helps others with bad radio reception.
Tom
Boulder CO
axnguyen
07-21-2015 11:41 AM
mike28117
07-17-2015 01:59 PM
