cabin air filter
Old Nov 11, 2006 | 09:36 PM
San Diego Bob's Avatar
Lightbulb cabin air filter
Acidic odor coming through vents some times. Dealers says change cabin filter behind the glove compartment. $125 parts $50 labor - $175. Is this the going price? Is there another solution? Can the filter be cleaned or removed and not replaced?
San Diego Bob
Old Nov 11, 2006 | 09:56 PM
patpur's Avatar
Senior Member/Moderator
Default Re: cabin air filter
You can clean it but that is dry debris. Sounds like you might have some mold going on there. The filter is easy to do yourself either way and probably way cheaper than what that dealer is quoting you. I'd buy one from parts and do it myself. I've had mine out and cleaned it. its a little tough to get to but with a little patience you can save a good del of money. Somebody here I'm sure will know the part number.
After you have it done or do it yourself try running your cabin fan on high for a few minutes before you shut your car off without the AC on. I've used this trick on my PT's and my Crossfire and never had an odor problem.
Pat
Old Nov 11, 2006 | 09:59 PM
Lightbulb Re: cabin air filter
Thank You Pat. I will try it myself.
Old Nov 11, 2006 | 10:08 PM
blacklimitedcoupe's Avatar
I paid $37.50 for my filter from the dealer and changed it myself. If I were you, I'd replace it about every 15,000 miles. Mine had 15,000 miles on it when I changed it and it was disgusting. Under the glove box you'll see a panel. Remove the screws and drop that panel out. Then you'll see a rectangular door. Pop that open and the filter will slide out. If you need help changing it, PM me and i'll walk you through it.
Old Nov 12, 2006 | 06:41 AM
bobs's Avatar
Do a search on this forum. I did a step-by-step write up on how to change it a while back.
Old Nov 12, 2006 | 09:06 AM
marauderroy's Avatar
The dealer is trying to rip you off. Get the filter and change it yourself. It's easy and quick.
Old Nov 12, 2006 | 09:48 AM
Iamfink2's Avatar
Do a search and I think you'll find a post by Andrew that has directions and pictures on how to change the cabin filter.
Old Nov 12, 2006 | 09:52 AM
andrew's Avatar
-C-I-C-C-I Associate Member
once you remove the lower cover/panel under the glove box & passenger foot well area.
this is what you see...
you need to slide back each clip (off white color) to remove filter cover... then pull filter out (it stands up on end).
pic of cover removed:
pics of filter at 25k (new - old): revised m/b part number
Old Nov 13, 2006 | 01:39 AM
Aero Blue's Avatar
Arrow Re: cabin air filter
I had service "B" recently done to my Crossfire which included a new cabin filter and the bill was $287, so I'd say just for them to replace the CF was about $165.00. My car had about 15K and it was VERY dirty. If your a do it yourselfer I say go for it, although it isn't as easy to replace as other cars, that's for sure!
Old Nov 13, 2006 | 02:15 AM
$165 is a bit stiff for a filter. Andrew's instructions do not look that complicated. I wonder what the benefit is for the Roadster?
Old Nov 13, 2006 | 09:39 AM
andrew's Avatar
the filter change is cake imo. total time maybe 15 minutes. 2 bolts remove cover... slide clips pull filter out... repeat.
as for the roadster... you need clean fresh air when the top is up... it will offset all that pollution you took in with the top down.
Old Mar 20, 2007 | 10:40 PM
dobro's Avatar
I just had my Roadster's cabin filter replaced at 26k. It was dirty and leafy, but not overdue.
I also had a 4 wheel alignment (uneven tire wear) and an oil/filter change.
Came to two fiddy plus tax at a wonderful independent shop in Plano, TX.
syfi
Mar 28, 2026 04:14 PM
Valk
Jul 12, 2021 09:49 PM
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
Sep 28, 2015 07:40 PM
