Spoiler question
Old Dec 10, 2006 | 03:55 PM
grphtmtlc11's Avatar
Default Spoiler question
All right, I understand it's freezing outside and that metal contracts when it's cold, but has anyone else ever had their spoiler squeak when it deploys? It just started happening when it got really cold outside. If anyone has the same problem or a solution, please let me know.
Old Dec 10, 2006 | 05:36 PM
dynamicS's Avatar
Default Re: Spoiler question
You might have to lube the linkages on the spoiler. I'm not sure what MBZ recommends but I would try and use a light weight mineral or penetration oil. Might just have a light rust coating on a bearing surface from water moisture.
Old Dec 11, 2006 | 04:18 AM
Idaho's Avatar
Do a search there is thread about lubricating the gear assembly behind the rear panel in the trunk.
Old Dec 11, 2006 | 02:30 PM
xfire-tech's Avatar
you need some krytox lubricant - -Mopar part#5019059aa. Then lube the motor bearing behind the electrical connector and also lube the gear wheel shaft and the gear wheel shaft bearing.
Old Dec 11, 2006 | 02:50 PM
bollox's Avatar
Maybe you have a rodent problem?
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
