Stuck in snow - You?
Video of Xfire stuck in snow on a level street. Anyone here?
http://www.youtube.com/watch?v=b-KUESYmF-Q
Re: Stuck in snow - You?
Originally Posted by stryfox
I drive mine in the snow. The trick is...if you are on a sheet of ice turn the traction control off!!!
If not you will just sit there.
on
I had no problems on fresh powder or street slush/ice coming back through Flagstaff, Arizona on January 5th. Woke up with 2 inches of fresh powder on the car and it did just fine.
I left it in 'W' mode and just went slow... no problems. A little slipping now and then, but nothing the traction control couldn't compensate for.
But then again, I have an Auto-Stick and all season performance tires... not a stick shift (most likely this person's biggest problem) and summer tires.
If you start out in 1st or 2nd gear on a stick, you have to be pretty good on the clutch to keep it from spinning.
Plus, I bet the driver had no extra weight in the rear cargo area. (I would have put another 200 or 300 pounds back there if I could).
on
With someone else in the car it's not a big deal... and I always understood that maximum weight capacity was in addition to the passengers, but I've been wrong before.
My wife and I were in the car along with probably about 150 lbs of luggage, so it wasn't as if the car wasn't 'laden'.
Freezer
08-06-2015 07:24 PM
