Xfire's Best Features
Old Mar 30, 2007 | 01:50 PM
  #81 (permalink)
CrucialCrossfire's Avatar
Default Re: Xfire's Best Features
Originally Posted by BillP2R
Now that I've had some chances to use my Crossfire, I have to say that the stock audio system creates the best "soundstage" of any stock system I've experienced.
- Bill
I second that!!!...i need my music..and have been wanting to put in at least an additional 10 inch or 12 inch sub...for over a year now..but other things keep on arising to where i have to spend the money saved for it on other more important stuff higher on the totem pole. So i must say that the stock system is also one of the best i have heard and is doing me just fine until i finally loose my mind and splurge and put the "system' on my credit card!
Old Apr 2, 2007 | 04:41 PM
  #82 (permalink)
posman's Avatar
Thumbs up Re: Xfire's Best Features
I just traded in my 2005 Magnum RT for my Standard Coupe and I could not be happier. The looks, price, and the cornering are amazing.
This car handles real good. The funny thing is, I've been telling everyone that asks me about the car in the past 2 weeks that the best feature was the cornering and looks The first thing that I read here is the "handles real good". Too cool.
Old Apr 2, 2007 | 05:15 PM
  #83 (permalink)
Sandgrounder's Avatar
I like the fact that I will be able to get out of my drive and onto the road within a couple of weeks! Its been a long cold winter sitting in the drivers seat, trapped in the garage.
Old Apr 16, 2007 | 10:58 PM
  #84 (permalink)
Mediacritic's Avatar
Awesomely tight turning circle. U-turns have never been so fun!
Old Apr 24, 2007 | 12:19 AM
  #85 (permalink)
bigpapapuff's Avatar
Talking Re: Xfire's Best Features
1. It's a great chick magnet.
2. It corners very, very good.
3. It costs one hell of a lot less than a Saleen!
Old Apr 24, 2007 | 12:55 AM
  #86 (permalink)
nascarhq's Avatar
One of my favorite things is the home link integrated remote control, no fumbling for remotes!
Old Apr 24, 2007 | 02:05 AM
  #87 (permalink)
tall_girl's Avatar
won't the whole anti-tow device system just make it worse? i mean, your right, the dude isn't going to get scared off my a horn, or siren, or whatever. and he's just going to end up having to DRAG my Xfire on its new, and painfully expensive tires up onto the tow truck...this seems like a no win situation for me quite frankly, seems i'd just rather not get towed in the first place...
Tall_girl
Old Apr 24, 2007 | 03:35 AM
  #88 (permalink)
Did I mention chick magnet and .9G corners? LOL.
Old Apr 24, 2007 | 08:26 AM
  #89 (permalink)
Gwetoe's Avatar
If you do not want you XF to be towed. Just back it into a spot where the tow truck driver cannot get to the tow hook under the rear bumper. A lot of people do not know that you have to remove the lower front grille to get to the front tow hook. The poor tow truck driver will have a heck of a time trying to find a place to "hook-up" the device with all the plastic shielding in the way underneath.
Old Apr 24, 2007 | 09:35 AM
  #90 (permalink)
Romio's Avatar
can't they just lock your wheels in the fork thing and pull you out?
Old May 1, 2007 | 11:43 AM
  #91 (permalink)
AMGLover's Avatar
Deleted Message
Old May 1, 2007 | 11:48 AM
  #92 (permalink)
Romio's Avatar
how do you change the display?
Old May 1, 2007 | 11:53 AM
  #93 (permalink)
AMGLover's Avatar
Deleted Message
Old May 1, 2007 | 11:56 AM
  #94 (permalink)
Romio's Avatar
Ohhh now i'm excited to get off work and go play with it.
Old May 1, 2007 | 12:19 PM
  #95 (permalink)
BRappaport's Avatar
Originally Posted by AMGLover
Didn't see these in the post.
1) speed sensing volume control on stereo.
2) Reset trip odo with engine off. Push odo stalk 2x then hold.
3) Window return on roadster. When retracting the roof if you hold the retract button past the end of cycle beep the windows will return back to the closed position.
4) Change Radio LCD from positive to negative (green w/black to black w/green).
- ej
"Speed sensitive volume control"...I do not think I have this...is this something you can program as a feature? If so...How? Can you actually see the volume db change with speed? If I set my volume to -20db...it stays at that setting...irrespective of my speed...unless I physically turn down the volume.
Ben
Old May 1, 2007 | 12:47 PM
  #96 (permalink)
AMGLover's Avatar
Deleted Message
Old May 1, 2007 | 02:32 PM
  #97 (permalink)
BRappaport's Avatar
You won't see the vol adjust... Beckers have a feature called GAL a speed dependent volume control 0= no volume increase +1 low speed initiation higher number, higher speed before it is initiated xf default is 10 (max is 15) so you will only notice this at highway speeds. It is plug 1 on socket A (bottom most socket).
- ej
Thanks for the reply...I wonder if the radio is connected to the same output on the speed sensor that drives the variable speed control for the windshield wipers?
Old May 1, 2007 | 04:15 PM
  #98 (permalink)
blackNJ's Avatar
I pushed the aud button in and all it did was reset the bass, balance fade and treble to 0. It displayed "linear" when it did it. I tried with the radio on and off. Does this not apply to the base radio with the black *****?
Old May 1, 2007 | 05:54 PM
  #99 (permalink)
Romio's Avatar
No i just tried my 04' coupe. It has the same radio as the 05's LTD's, and it just said LINEAR and reset everything to 0. How do you get to the user menu?
Old May 1, 2007 | 06:10 PM
  #100 (permalink)
Fenwick223's Avatar
Just a thought but could this feature be available on the replacement radio (the one that was installed under the TSB) with the brighter screen and not on the original radio with the dim screen?
