Removing Headlights
Old Mar 8, 2007 | 02:17 PM
Blade's Avatar
Default Removing Headlights
I recently purchased a new set of headlights on ebay to replace my current ones. Upon trying to remove the old ones, I noticed that there appear to be 4 screws that hold the headlamp in, yet my hand can only reach 2 of them. Has anyone had to remove the headlight before, and, if so, how did you get to the bottom two screws?
If your dealer did it for you I'm not interested in your story, obviously.
Thanks.
Old Mar 8, 2007 | 02:58 PM
danimal's Avatar
Default Re: Removing Headlights
I was reading it in the service manual several days ago and it mentioned removing the bottom two bolts through an access in the fender well. I have not looked, nor attempted it, but I'm wondering if they are talking about through the access behind the fog lights?
The reason I happened to be reading that is because that's the way they recommend changing the bulbs...by removing the whole headlight assembly first.
Old Mar 8, 2007 | 03:05 PM
cfire520's Avatar
Have you downloaded the service manual from this thread? It should help.
https://www.crossfireforum.org/forum...ad.php?t=13875
Old Mar 8, 2007 | 03:08 PM
Fenwick223's Avatar
And here is where you find the service manual:
http://www.gleamingedge.com/mirrors/...e%20Manual.pdf
I've only owned a Crossfire for less than 2 weeks but I have to tell you that this manual answers just about every question you can have. I downloaded it and then open it by itself; it's a very large file and tends to bog down my computer and mine is pretty good. It's about 3,300 pages in a .pdf format.
Old Mar 8, 2007 | 05:36 PM
Blade's Avatar
Excellent.
Thank you gents.
Old Mar 8, 2007 | 07:59 PM
patpur's Avatar
Senior Member/Moderator
There are removable covers in the front of each front wheel well, perhaps those are the ones to get to the headlights and those screws?
Pat
Old Mar 9, 2007 | 06:10 PM
Blade's Avatar
Well, I got all of the bolts out today...only to find that the headlight cannot be pulled out. It seems that the front bumper will not allow it.
I really, really, hate working on german cars.
Old Aug 1, 2008 | 02:17 PM
OzCrossfire's Avatar
Ok... was replacing a headlight bulb today and the spring clip came out and dropped down inside the headlight assemly. Are you telling me that in order to get this out by removing the headlight totally, and shaking it, that I have to remove the bumper???
Please help before I attempt.....
Old Aug 1, 2008 | 02:30 PM
MI1XFIRE's Avatar
You can get it out by removing the2 bolts in the engine compartment that hold the upper part of the bumper cover. If I remember correctly you'll have to pry gently on it to snake the headlight out. I almost forgot, take the grille out first
Old Aug 1, 2008 | 03:12 PM
HI MI1XFIRE... thanks so much for the quick response. I had only just undone the bottom bolts on the headlight and was trying to pry it out. Will try it with the bumper bolts undone and see how I go. Thanks heaps.
Brett
Old Aug 1, 2008 | 03:23 PM
HI MI1XFIRE That worked a treat. There is a large bolt at the bottom of the headlight assembly which needs to clear the bumper at the bottom of the headlight. By undoing the two bolts it gives just enough flex of the bumper to twist the headlight over the bumper and pop the headlight out. Careful not to scratch the bumper with the bolt though so do it with care.
Thanks again for the response. Hope this helps someone else someday.
Cheers
Brett
Old Aug 1, 2008 | 05:07 PM
MI1XFIRE's Avatar
Cheers
Brett
You're welcome
usprb1976
Apr 4, 2024 04:57 PM
onehundred80
Aug 6, 2016 12:03 PM
smokey847
Nov 12, 2015 11:54 PM
jaesa
Sep 7, 2015 01:50 PM
williammt
Sep 6, 2015 11:23 AM
