Need New Tires... Recommendations, Please...
Old Jun 28, 2007 | 10:33 AM
roadrunner6656's Avatar
Default Re: Need New Tires... Recommendations, Please...
Goodyear Eagle F1 GS-D3 - even better in the wet than dry! I'm in the UK and bought four for £550 from Quick fit after they price matched an internet quote.
Old Jun 29, 2007 | 01:57 AM
anilkumar's Avatar
Hey guys... I could of swore they made runflats for our cars... I can't seem to find them...
Old Jun 29, 2007 | 10:36 AM
Chris A's Avatar
UK member here 2003 xfire Coupe Auto 60k. Michelin Pilot Sport were fitted as standard from new. Lasted 32k on rear 42k on front. Replaced rear with Pirelli P Zero Rosso lasted 11k, sticky but wow the wear rate! Now on Conti's doing OK with 16k on them but more than 50% worn now and liable to give way without warning near the limit. Had Kumo on the front and they were OK but hard and noisy and tram lined something awful. I had to replace them due to a tracking problem after ball joint change and have returned to Michelin. God I didn't realized how much I missed them.
Stick with Michelin costly but worth every penny.
Old Jul 1, 2007 | 08:29 AM
Buck70's Avatar
Originally Posted by anilkumar
I wanted to know what you guys have put on your X fire... What works best, as far as road noise, wet weather, handling, etc... Do we get Runflats??
Thanks,
anil.
https://www.crossfireforum.org/forum...1&d=1182608161
I bought tires for last winter, the Dunlop winter sport and the Blizzaks made a great winter combo. They were also very good in dry and wet conditions.
The only reason they are off right now is to use up the last of the OEM Michelins during the dry season, and keep the snows as fresh as I can for next winter. Price was good for an odd size high speed tire IMO.
DB
Old Jul 1, 2007 | 10:18 AM
jhendri2's Avatar
I'm running Toyo Proxes T1R's right now. I like them pretty well.
Old Jul 10, 2007 | 09:19 PM
lewy xfire's Avatar
dunlop makes a run flat in our rear tires
dunlop sp sport 9000 dsst
More recently in Europe, Dunlop has sold ultra high performance tires which incorporate a new run-flat technology that is designed to be mounted on current original equipment and aftermarket wheels. This run-flat technology is being introduced in the United States by incorporating it into Dunlop's flagship "HydroMax" performance tire, the SP Sport 9000. This new run-flat tire line currently offers five sizes and has been named the SP Sport 9000 DSST, with the DSST suffix identifying that it utilizes Dunlop Self-Supporting Technology.
Designed to continue running for up to 50 miles at speeds up to 55 mph even after sustaining air pressure losses which would render conventional tires unusable, SP Sport 9000 DSST tires allow drivers the convenience of being able to better choose when and where they will have their tire repaired. For that matter, when driven straight down the road or on the highway, SP Sport 9000 DSST tires are so good at masking the traditional loss-of-air symptoms which accompany a flat tire, that they require a tire pressure monitoring system to alert the driver that they have lost air pressure.
Old Jul 12, 2007 | 11:18 PM
stevules's Avatar
i've got 52,000 km on mine and am almost to the mark on the rears, fronts are still ok and original brakes, i'm impressed.
vnrcoop
West Forum
Oct 4, 2018 01:09 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
debradegiovanni
Sep 27, 2015 09:39 AM
Jackobo
Sep 24, 2015 10:21 PM
Power Sedan
Sep 20, 2015 09:24 PM
