Hot Wire/Firewall
Old Jul 1, 2007 | 11:07 AM
XFire Woodie's Avatar
Default Hot Wire/Firewall
I need a hot wire to install an additional power port (cig lighter type) for GPS, Ipod, etc. Has anyone found a hot wire on the inside of the firewall or an empty fuse block location that is suitable for this? If not, hows the best way to get a hot wire to the under dash area? Switched or unswitched is OK. Thanks.
Old Jul 1, 2007 | 03:46 PM
bobs's Avatar
Default Re: Hot Wire/Firewall
I tapped into the wire that powers the cigar lighter. It's switched, BTW. It's pretty easy to get to as well. Grab the trim around the gear shifter and pull straight up. It'll pop right off and give you access to the wire.
Old Jul 1, 2007 | 11:58 PM
Thanks Bob, that's exactly the kind of info I needed.
Nov 11, 2015 05:22 AM
nataliefs
Oct 5, 2015 01:03 PM
Oct 1, 2015 01:42 AM
waldig
Sep 17, 2015 10:35 AM
PA/XFIRE
Sep 5, 2015 01:25 PM
