Towing Eye Front
Old Jul 12, 2007 | 11:49 PM
wkirch's Avatar
Default Towing Eye Front
I did not get the tool to take off the front grill passenger side to get to the towing hook for towing. I tried a long screw driver but it didn't seem long enough. Does anyone know how long the screw driver needs to be so I can buy one in case I need to be pulled up on a flatbed. I called the local Chrysler Dealer but he was having trouble finding the part in his books. Fore owners the process is explained on page 171 of the owners manual and it also shows the tool. Any help would be appreciated.
Old Jul 13, 2007 | 12:23 AM
radmanly's Avatar
Default Re: Towing Eye Front
I just want to add a "me, too" here. My Limited didn't come with this tool, either. A Mopar part number would be a big help.
Old Jul 13, 2007 | 12:29 AM
midnightman's Avatar
The "tool" is a joke.
Just stick your finger in the outer opening in the grill and pull. It pops right out.
Old Aug 5, 2007 | 10:32 PM
Crossfireone's Avatar
For me the tool works real well. My fingers are not that small to hook in hole & pull. My car didn't come with one either, but I knew it should have been packed in the glove box, so when I mentioned it to the dealership they ordered it in right on the spot thru their parts dept. The part # is 1-05140795AA.
This should be at no cost to you since it is part of the customer shpg. pkg. from Germany, or should have been.
Good luck,
Crossfireone
Old Aug 5, 2007 | 10:45 PM
andrew's Avatar
-C-I-C-C-I Associate Member
here is a pic of the metal tool:
Old Aug 9, 2007 | 06:34 AM
John Webster's Avatar
I found that thing one day when I was digging in the bottom of the pouch on the rear bulkhead. I had no idea what it was for.
Old Aug 9, 2007 | 07:52 AM
andrew's Avatar
it is also used to aid with the shift linkage if problems occur... in automatic form. tool to be inserted to the left of the shifter (at the small opening).
see manual for a better description.
Old Aug 9, 2007 | 09:24 AM
BillP2R's Avatar
That's where I found mine too.
- Bill
Old Aug 9, 2007 | 09:44 AM
danimal's Avatar
It's also used as a manual release for the top (in the down position) on the roadster. I guess "multifunction tool" is more than appropriate.
Old Aug 9, 2007 | 11:48 AM
CrossfireLTD's Avatar
Cool Re: Towing Eye Front
Also check in the area of the trunk where the tire sealant is kept...that is where I found mine.
chturner
19
Oct 14, 2019 04:42 PM
cjw
Oct 26, 2015 10:26 PM
cjw
Sep 27, 2015 10:22 AM
Posimoto
Sep 13, 2015 06:13 PM
Vegaslegal
Sep 10, 2015 11:24 AM
