Another winter storage question
Old Sep 25, 2007 | 05:09 AM
radmanly's Avatar
Default Another winter storage question
I've read that you should change the oil and oil filter before storing your car for the winter. My oil was changed 700 miles ago. Do I need to change it again even though it has such low mileage?
Old Sep 25, 2007 | 08:53 AM
RPM's Avatar
RPM
Moderator
Default Re: Another winter storage question
I would think that you will be fine, no need to re-change the oil/filter IMO.
Old Sep 25, 2007 | 09:58 AM
Sandgrounder's Avatar
I will piggy back on your thread, for winter storage(if thats OK). Due to tight space in my garage I can't access the right hand side to jack the Crossfire up and install jacks to take the weight off the suspension! However it has been suggested that the minimum I do is to roll her up onto wooden blocks to prevent any interaction with the cement floor, Styreen has also been suggested. Question what should be the min thickness under the tires??
Old Sep 25, 2007 | 10:34 AM
RPM's Avatar
RPM
Moderator
I would say 1/2" to 1" will work. The foam I use is probably ~ 1/2" thick.
Put a tarp (or 2) under your car (on the concrete), and the foam or wood on top of the tarps.
Old Sep 25, 2007 | 07:14 PM
radmanly's Avatar
Thanks for the reply, RPM.
Can anyone recommend a car cover? Has anyone tried one of those zippered car storage bags?
Old Sep 26, 2007 | 03:13 AM
RPM's Avatar
RPM
Moderator
radmanly - I purchased a Mopar cover through http://www.wyckoffchryslerparts.com/
The fit is superb. The material is kind of like a windbreaker.
My father-in-law covers his Vette w/a soft cloth cover and it collects a lot of dust.
Just depends on what type of cover you are looking for.
Old Sep 26, 2007 | 03:43 AM
RickZ's Avatar
OK what is everybody's trick to keep mice out of it ? I have put Bounce dryer sheets in and around and of course D-Con around, but that is one of my biggest fears. They can do a lot of damage.
Old Sep 26, 2007 | 04:10 AM
Mr. F's Avatar
Google Car Capsule. that's what i'm going to try.
Old Sep 26, 2007 | 05:08 AM
radmanly's Avatar
Is the inside sufficiently soft that it won't scratch the paint?
Old Sep 26, 2007 | 05:15 AM
RPM's Avatar
RPM
Moderator
Not sure. I guess I would put mouse traps or the like underneath or around it.
You might want to Google that question and see what some of the collector car guys do. I found some good links a while back (they are posted on here somewhere, can't remember where though).
I think so. Though I will put a coat of Carnauba wax on before I cover it for the winter.
It is not as soft as a cloth cover, but as long as your car is clean and has a good coat of wax, I would think it would be fine.
Old Sep 26, 2007 | 05:28 AM
radmanly's Avatar
Thanks, RPM!
Old Sep 26, 2007 | 07:30 AM
radmanly's Avatar
After a little more research, I decided to order a cover from Car Cover USA. They have covers specifically designed to fit all Crossfire models and they cost less than the Mopar cover from Wyckoff. I'm also going to get a CarBag to keep critters out. CarBag doesn't list the Crossfire but I believe sizes M1 or M2 should fit. I'm going with the larger M2 just to be safe.
Old Sep 26, 2007 | 01:51 PM
orland06xfire's Avatar
i'd change the oil after the winter. not for the need of changing it but as to not completely dry start the motor.
Old Sep 26, 2007 | 02:01 PM
radmanly's Avatar
I plan on starting it at least once a month over the winter.
Old Sep 26, 2007 | 03:25 PM
acrispy1's Avatar
This is what i'm looking to get.
http://www.car-capsule.net/?gclid=CL...FRMSgAodtSS9Tw
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
