first time oil change - but question?
Old Oct 11, 2007 | 07:17 AM
strupgolf's Avatar
Default first time oil change - but question?
I drained all the old oil uut, put a new filter on, got the FSS right> I only put in 8.2 quarts, but now the dipstick shows over max. Should I drain some of the oil out to get it down between the marks, or what? Thanks.
Old Oct 11, 2007 | 07:20 AM
maxcichon's Avatar
Default Re: first time oil change - but question?
What does the FSS say? The electronic Oil Level Indicator.
Old Oct 11, 2007 | 07:33 AM
beasticles's Avatar
I wouldn't worry too much, once you start driving around it should level out.
Old Oct 11, 2007 | 07:50 AM
RPM's Avatar
RPM
Moderator
I put 8 qts and the filter in. Let it run for a few minutes, then add the other 1/2 qt. All is well.
Old Oct 11, 2007 | 07:52 AM
strupgolf's Avatar
Where can I find the electronic oil level indicator? The mileage shows 7,000, but is there a symbol nearby?
Old Oct 11, 2007 | 08:25 AM
Maxwell's Avatar
the dash gauge on my car always reads 1 quart too high.
msheredy's Avatar
Drive your car around a bit. Let it set for 5-10 minutes then check the oil. If it is too high I would drain some out. More oil is in some cases worse than too little oil.
I end up putting 8 qts in my oil changes now.
Old Oct 11, 2007 | 09:29 AM
maxcichon's Avatar
Sorry. I should have told you to read the manual (RTFM to those in the repair/manufacturing biz) to find out how to ask your car for this info. It's in the FSS section.
Old Oct 11, 2007 | 10:18 AM
Turn the key to on/run position. Wait several seconds for the odometer display area to show a symbol for your oil and then press your reset button for the trip meter twice to see the display for your oil level.
My car only requires 8 quarts with a oil and filter change and it is right on full on the dipstick.
Old Oct 11, 2007 | 11:54 AM
maxcichon's Avatar
I just looked for the first time at my dash level indicator and the dipstick.
Dipstick is at the high mark (cold).
Dashboard says "o.k.".
Just "o.k."? Not "+1/2" or "-1"? Just "o.k."?
I feel somehow cheated...
Is this normal?
4drturbo
Jan 3, 2019 02:46 PM
axnguyen
Jul 21, 2015 11:41 AM
skeet370
Jul 18, 2015 01:02 PM
JEFASOLD
Jul 15, 2015 02:32 PM
bradleykologek
Jul 6, 2015 02:49 PM
