New Owner with Question!
Old 10-17-2007, 10:35 AM
ApolloFX's Avatar
Question New Owner with Question!
I've been looking to take the plunge and buy a Crossfire for a long time and yesterday I finally did, its a '04 Black Coupe w/ Cedar/Slate interior. It's an amazing car no question. Unfortunately I had quite a drive home after purchase and of course a deer jumped in front of me, I SLAMMED on the brakes and both the deer and the car made it without a scratch. Well the next day I get in my car and see the BAS ESP light on. I assume it has something to do with my emergency stop? Has anyone had this experience, I searched the forum but couldn't find a definitive solution, Id prefer to avoid the dealership if its an easy solution as I only have powertrain warranty remaining.
Oh I tried the left-right calibration trick, no luck. Also unlike others who posted with this problem my spoiler functions as normal, my traction control turns on and off, and it shifts with no issues.
I may have to head to the dealership but I wanted to check with you guys first .
Thanks for your help!
Old 10-17-2007, 10:44 AM
+fireamx's Avatar
Default Re: New Owner with Question!
ApolloFX, first off, welcome to the forum. I've got the cedar interior too and I love it.
Try disconnecting the battery for about 10 minutes, and then reattach the cables. Drive it for a little while and see if it doesn't go out on its own. Mine did.
Good Luck.
Old 10-17-2007, 10:53 AM
patpur's Avatar
Senior Member/Moderator
There is a fix in your owners manual. I'm not sure what page its on but it involves turning the steering wheel, on a flat surface full to the left and full to the right and back to center, I believe the key has to be in the on position. This should reset the BAS/ESP system.
I'll find the page when I get home this evening. Mine did the same thing and it takes a while (few hrs) to clear itself. Did your spoiler go up when this happened? Mine did and I got a flashing warning light on the dash.
Same thing happened in our Mercedes and they just placed the steering angle sensor. Hope yours is the easier fix. Welcome to the forum.
Pat
Old 10-17-2007, 10:59 AM
beasticles's Avatar
Patpur, reading Apollo's post I am pretty sure his "left-right fix" is the same thing you are talking about.
Old 10-17-2007, 11:16 AM
ApolloFX's Avatar
Thanks for your fast answers guys!
I tried that calibration trick in the manual before I posted, no luck unless I'm doing it wrong. I turned it center-left-right-center with the engine on in park and the light doesn't go off. On a different note after I turn off the engine and then back on the light stays off till I push the brake in, then the lights back. I haven't tried to disconnect the battery yet as suggested above but I'll try this when I get home.
Old 10-17-2007, 02:30 PM
CrossfireLTD's Avatar
Cool Re: New Owner with Question!
Congrats & Welcome to the Forum!!!
Disconnecting the battery should do the trick.
Old 10-17-2007, 03:55 PM
patpur's Avatar
After I did the reset it took overnight before the problem cleared up?
try the battery fix if that doesn't do it your options that I know of are stop light switch (works off the brake peddle), steering angle sensor or the ABS sensors. You have to get someone to pull the codes for you if our fixes don't work. Good luck and let us know how you make out.
Pat
Old 10-18-2007, 08:46 AM
ApolloFX's Avatar
Well I did everything you guys suggested but no luck.. It'll probably go to the dealer soon. Is there any place out there that sells a reasonably priced code reader for the crossfire? Seems like it would be a good investment...
Old 10-18-2007, 11:39 AM
jackei's Avatar
It happened to me once, I can't remember what I've done to trigger the BAS/ESP light. I tried the left and right calibration trick in the manual but won't work neither. I was planning to bring it to the dealer, but I was too lazy. And after a couple weeks, the light was gone and good as new.
Old 10-18-2007, 11:47 AM
04Fire's Avatar
A couple of weeks? That's a huge time frame... overnight too a couple of weeks.
I've only slammed on my brakes a few times and I never got any lights other than the traction control (TC) light.
Old 10-18-2007, 12:11 PM
jackei's Avatar
You read correctly, a couple weeks.
The light actually goes off after parked for the weekends, but came back on Wednesday, and more frequently on Thursday, and stayed on Friday.
I can't remember for how long, maybe 3 weeks, then the light is gone and never have that problem again, so far, touch wood.
Old 10-22-2007, 10:23 AM
ApolloFX's Avatar
Smile Re: New Owner with Question!
I took it to the dealership last Friday. They diagnosed the brake/stop light switch as one of you suggested as a possibility. I was actually driving without any brake lights all week, luckily I didn't drive much last week as I didn't even notice! I had it replaced and problem solved!
Old 10-24-2007, 07:20 AM
Hi,
I'm from Johannesburg, South Africa.
I have had my Crossfire 11/04 for 3 weeks now she was a demo model with 2,500 km on the clock when I got her. That's 1,550 miles
Been loving every minute of her...keep making excuses to drive everywhere...sure getting alot of looks.
Been scanning the forum and got alot of invaluable info thanks.
Laterzzz...
TinTin
Old 10-24-2007, 08:51 AM
04Fire's Avatar
Originally Posted by tintin
Hi,
Laterzzz...
TinTin
Well first off... Welcome to the forum!
You'll find everything you need and then some... see you around.
KDW4Him
18
09-01-2021 05:47 PM
toob
Crossfire Events and Meets
09-26-2015 02:22 PM
MAXIMUM
08-04-2015 11:04 PM
PNA
Car Shows
08-03-2015 08:22 AM
PNA
07-13-2015 11:40 AM
Quick Reply: New Owner with Question!
