This really works! How to repair leather creases and indentions!
Old Oct 27, 2007 | 10:29 AM
cgocifer's Avatar
Default This really works! How to repair leather creases and indentions!
This really works! Take your time and be careful with the iron not to touch anything directly!
After a long story posted in another thread, my leather on the pass. seat was damaged. Severe creases and indentions so deep, they were nearly punctured by heavy components that were placed on the seat for a long period of time by a dealership. Instead of having them screw up further, I fixed it my self using the following method:
After some research, I used one of those vinyl repair kits that you can get from the auto parts store that I had laying around the garage. It has a little electric iron with a circular end. Also in the kit are textured pieces of heat resistant paper. I placed the paper on the creases, and indentions, then used the iron in a back-and-fourth motion. To my surprise, the leather is back to normal with the exception of a centimeter sized indent. Only I can see it because I know where it is. Turns out, leather will stretch back into shape when heated. I tried it on some wear creases too with success. So, if any of you have some deep creases you would like to minimize or remove, give this a try, it works great!
*If you don't have a kit like I mentioned, a regular iron will work and a heavy towel. Just be careful not to touch anything with the iron unless covered by the towel.
This thread can be moved to the tech. area, but I wanted to share with a wider audience first.
Old Oct 27, 2007 | 11:39 AM
MAYAman's Avatar
Default Re: This really works! How to repair leather creases and indentions!
Pics please.
Old Oct 27, 2007 | 11:43 AM
Maxwell's Avatar
I would take it to an upholstery shop and first have them steam it out, then send the bill to the dealer.
Old Oct 27, 2007 | 02:54 PM
NeverEnough's Avatar
I have seen this work. I had a customer with a used Dodge Ram truck that had a similar issue with a vinyl door panel. I watched the repairman do exactly what you are describing and in about 2 minutes it was gone. I've never had the need for this type of repair, but I would have a professional do, I don't think I would have the guts to try it myself.
Old Oct 27, 2007 | 10:23 PM
cgocifer's Avatar
No really, it's very easy and very simple to do. Remember, leather is skin and very durable. Just make sure you have a towel down or a paper like I mentioned. Practice on a wallet or purse or something. It's very easy.
Old Oct 28, 2007 | 01:54 AM
malcb's Avatar
I was surprised how easy it is to leave a mark in the leather - I left a small pcb board on the seat overnight and the transformer left an indentation. Transformer was quite small only 1/4 lb. I thought it would come out in time but it's still there so I will try this, thanks.
KDW4Him
18
Sep 1, 2021 05:47 PM
Kodebuster
Nov 5, 2020 04:06 PM
XFIRED-TX
Jul 17, 2015 11:56 AM
XFIRED-TX
Jul 14, 2015 10:48 PM
Rusty475
Jul 13, 2015 10:03 AM
