Tons of oil leaking from engine! Help!!
Old Dec 31, 2007 | 07:54 AM
all_Bran's Avatar
Default Tons of oil leaking from engine! Help!!
Is there a common problem with these engines leaking oil? We went to back the car out of the garage and there was about 0.25-0.50qt of oil on the floor! When we got it out of the garage, there was a couple fresh spots on the driveway. It looks like it's coming from the passenger side of the transmission. There's a little hose line that runs to the side of the trans, that looks like it has a little rubber boot on it... Just in front of the firewall. And the boot and loom on that line is all wet with what looks like the same oil.
Old Dec 31, 2007 | 08:06 AM
Iamfink2's Avatar
Default Re: Tons of oil leaking from engine! Help!!
If its reddish its the transmission TSB 21-002-05 AUTOMATIC TRANSMISSION FLUID WEEPAGE 2005-01-14. I take its an automatic transmission.
Old Dec 31, 2007 | 08:48 AM
all_Bran's Avatar
You know what, I thougth it was reddish... But the manual said that "there is no need to ever check the ATF so there is no dipstick". I figured I was safe... LOL!!! I will call the dealership and give them the tsb number...
I thougth ATF was way more red than what was on the floor... Apparently not! It was a brownish redish color...
Thanks!!!
Old Dec 31, 2007 | 09:49 AM
Bill F's Avatar
It happened to me. I was surprised to see it with only 7,500 miles on my 2005 Xfire. In and out of the shop in a couple of hours.
Old Dec 31, 2007 | 11:34 AM
Fritzauf's Avatar
Same thing happened to mine at ~7500 miles in February 06. Dealer repaired in a couple of hours. They also replaced the cooling fan module (per recall). Hasn't been in the shop since. A fairly common problem and a simple repair. Replaced an O-Ring on the transmission. I was impressed with the service.
Old Dec 31, 2007 | 07:59 PM
fyrepower's Avatar
same thing happened to my 06 coupe at 13,000 miles.
Old Dec 31, 2007 | 08:27 PM
Cobra953's Avatar
I also had this problem, and thought it was the dreaded transmission leak. Turned out to be the oil pressure sending unit was leaking. Check your engine oil level, and see if it is down. Also look on the inside, with the hood open, and see if there is oil seepage on the belly pan, in the rear on the passenger side, a good indicator it is the oil pressure sending unit.
Covered under warranty. It requires the oil pan be dropped. Chrysler covered the oil, but would not pay for the filter (go figure!) when I asked for a change, since they had to drain the oil for the repair. Dealer did a great job.
Hope this is helpful.
Old Jan 1, 2008 | 12:26 PM
all_Bran's Avatar
Yup, sounds like the same problem. But it had nothing to do with the TSB posted before. Totally different area. But same problem.... some kind of gasket on the electrical wiring harness going into the tranny. $100 deductible on my extended warranty...
Old Jan 1, 2008 | 05:09 PM
Shawnkey's Avatar
almost all the nag trannies(the mercedes trans we use) leak from that plug. done about 50 myself.
Old Jan 1, 2008 | 05:47 PM
Punkin's Avatar
I'm encouraged to see and hear that the service was good for you guys. 2008 is just getting better and better.
Old Jan 4, 2008 | 04:35 AM
all_Bran's Avatar
Pardon my language, but that is ******* ridiculous...
Old Jan 7, 2008 | 03:21 PM
PowerOn's Avatar
Just had mine done... wasn't exactly sure what "nag connector" was at first either
Didn't drive it for a couple of weeks and it left a nice puddle on my new driveway pavers... but Griot's Oil and Grease Cleaner took care of it
4drturbo
Jan 3, 2019 02:46 PM
jgreen
106
Sep 18, 2017 11:46 PM
OLDawg
Aug 9, 2015 07:44 AM
Crossfireconv08
Jul 30, 2015 12:11 PM
chturner
Jul 24, 2015 04:47 PM
