oil filter lube rings
Old Jan 7, 2008 | 04:14 PM
doublediz's Avatar
Default oil filter lube rings
When the dealer changes your oil do they take these lube rings off when they take the filter off? I gave them a filter but the rings were still in the box. Was not sure if the filter just slides off without the rings popping off. If they did not put the rings on, is it gonna work properly?
Old Jan 7, 2008 | 04:18 PM
VQ35DE's Avatar
Default Re: oil filter lube rings
They should have used the new o-rings. Maybe it won't leak.
Old Jan 7, 2008 | 05:29 PM
ben47's Avatar
Another fine example of 5 Star Service....
Old Jan 7, 2008 | 05:30 PM
doublediz's Avatar
No leaks so far, maybe they used the old rings. Looks like I may just do a change myself at 3K instead of 7K to be safe.
Old Jan 7, 2008 | 05:39 PM
Moparrbust's Avatar
They most likely just left the old ones on which "shouldn't" cause any true issues if it's a one time deal. There would be no external leaks; unless the big o-ring failed, if there was/is a problem with the little o-rings but decreased oil pressure may be a result if they don't seal properly.
Old Jan 7, 2008 | 05:41 PM
doublediz's Avatar
If I had decreased oil pressure would the oil light come on at all?
Old Jan 7, 2008 | 09:19 PM
cgocifer's Avatar
Just take out the assembly and change the rings your self or better yet, take it back to the dealer and ask them to explain why they didn't follow the standard procedure.
Old Jan 8, 2008 | 05:57 PM
Moparrbust's Avatar
If it gets low enough to be damaging then either a light will come on or the engine will shutdown if it has a low pressure switch like most modern cars. I haven't familiarized myself completely with these cars yet as I am new to this scene.
Old Jan 8, 2008 | 08:13 PM
The filter can be removed and replaced without removing the four O-rings but they probably should still be replaced. If you still have them either go back and have them put them on or simply remove the filter assembly , remove the filter and replace them yourself.
Old Jan 8, 2008 | 08:20 PM
HDDP's Avatar
Unscrew the filter and look to see if the O rings are on the housing... More than likely, they just replaced the filter and left your old rings in place...
Old Jan 9, 2008 | 05:40 PM
doublediz's Avatar
Yeah I just did not want to take filter out without doing another oil change.
Old Jan 9, 2008 | 06:37 PM
DrMike's Avatar
Bring it back, they screwed up, change these every time filter is changed, they do crack from heat and contact with lubricant.
Talk to the Service Manager, not clerk.
Possibilty of leakage will happen when you dont expect it, filter manufacturer would not include if not required.
Old Jan 9, 2008 | 06:51 PM
HDDP's Avatar
You can remove the filter without having to change the oil again... It just unscrews and lifts right out... Either way, It is recommended to change the O rings because they do eventually degrade, but not necessarily as quickly as one oil change...
Old Jan 10, 2008 | 04:36 PM
doublediz's Avatar
Ok I will give it a shot tomorrow and take a look.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
