Tie Rod Issue
Old Feb 12, 2008 | 12:52 PM
dcspride's Avatar
Default Tie Rod Issue
About 2 months ago, I brought my car in for alignment and my dealer said tie rod is loose so they will replace it and cover under warranty. Week ago, I brought my car in for oil change and they found out tie rod is bent and they need to replace it...It will cost me almost $800 to replce it and sounds bit hight to me... is this about right price??
Old Feb 12, 2008 | 01:13 PM
sonoronos's Avatar
Default Re: Tie Rod Issue
A bent tie rod would cause some pretty bad steering and driving problems.
What proof do you have that your tie rod is bent? Also, which tie rod?
Old Feb 12, 2008 | 01:22 PM
dcspride's Avatar
well...my steering wheel was pulling towards driver's side pretty bad before so I though I had to get an alignment.... but when I went to get my oil change done, I asked them to check the air pressure on my tires and after they checked it, I didn't had steering wheel pulling to one side issue anymore. I don't have any proof other than service dept telling me that I have bent tie rod...I belive they told me driver side tie rod is bent and they need to replace the linkage and damper(??). And $800 cost includes parts and labor.
Old Feb 12, 2008 | 01:39 PM
robby363's Avatar
Did you ever hit a curb or pothole? I can't see bending a tie rod without some other suspension damage.
Old Feb 12, 2008 | 01:41 PM
dcspride's Avatar
Well, I live in downtown Boston...so I won't say I never hit a pothole before....Never hit a curb but I did hit big pothole couple times..
Old Feb 12, 2008 | 01:50 PM
+fireamx's Avatar
I'd get a second opinion from an idependant alignment shop that has a good rep. first.
If they tell you it's bent, find out from them "everything" you need to get it fixed by them. Then price everything out from a parts store.
$800 sounds high to me, but everything at your friendly neighborhood Chrysler dealer usually is.
This is something that doesn't need to be fixed at a Chrysler dealer.
Old Feb 12, 2008 | 02:04 PM
dcspride's Avatar
any recommendation to where I can order chrsyler parts for decent price??
Old Feb 12, 2008 | 02:08 PM
RPM's Avatar
RPM
Moderator
www.chryslerpartsdirect.com
Old Feb 12, 2008 | 02:09 PM
robby363's Avatar
This is the cheapest I've seen.http://www.parts.com/chrysler/2006-c...kage-parts.cfm
Old Feb 12, 2008 | 02:17 PM
robby363's Avatar
It looks like you have to by the Linkage assy as a whole part it might be cheaper for aftermarket parts if available.
Old Feb 12, 2008 | 02:20 PM
crossfirefun's Avatar
A bent tie-rod should make the steering wheel tilt one sided instead of straight across when traveling down the street. Are you sure it didn't get bent when they picked it up with the lift? As stated above I would bring it to an independent alignment shop. Have them check it for you. Or your friendly mechanic.
An inspection station that handles foriegn cars might help you out also. Not to say that is what is happening here but I see lots of uneeded work being asked for at dealerships.
Old Feb 12, 2008 | 02:26 PM
robby363's Avatar
I was thinking the samething it wouldn't be the first time I've seen a dumass in a shop lift a car up by the suspension I can't see bending a tie rod without breaking a tire or rim.
Old Feb 13, 2008 | 09:32 AM
dcspride's Avatar
thanks for all your reply guys.... I will definitely look into this.... will go to independent shop to ask them.
Old Jan 21, 2010 | 02:30 PM
GuyWagon's Avatar
Hello all,
Any crossover part numbers from Mercedes for the tie rod assembly also called the drag link?
Thanks
...GuyWagon
Old Jan 21, 2010 | 03:15 PM
Thirteendog's Avatar
Does this story ever end? I'd like to know if he shelled out the $800 dollars to get it fixed or if he took it elsewhere.
Old Jan 22, 2010 | 05:52 PM
04Fire's Avatar
The reason the estimate may be high is because a steering damper from Chrysler runs $400... when you can get the same thing by stabilus one for $30 on line.
55chevy
Jul 22, 2024 02:31 PM
Reliableron
Oct 17, 2015 10:19 PM
jimf
Oct 10, 2015 10:22 AM
ozkancab
Sep 25, 2015 10:55 AM
RiderJC
Sep 7, 2015 11:19 PM
