How to program Beep
Old Apr 21, 2008 | 04:22 AM
SET4ORD's Avatar
Default How to program Beep
Hi, does anyone know how to program the beep when unlocking and locking the car? It would be great to hear it and know the doors are locked. I heard this can be done. Any help would be great. Thanks, Patty
Old Apr 21, 2008 | 05:31 AM
blacklimitedcoupe's Avatar
Default Re: How to program Beep
do a search and you'll find numerous articles relating to this...
Old Apr 21, 2008 | 05:35 AM
imabenz's Avatar
The alarm cannot be programmed to chirp.
However, there are two modifications that can be made that will produce a chirp. One involves replacing a factory part and the other involves incorporating a simple "beeper" into the alarm circuitry. Both seem to be simple mods that you can do yourself. You only need to do one of the mods in order to produce a chirp.
Search for "alarm chirp". Sorry, I do not have the details, but this info will at least get you started.
Old Apr 21, 2008 | 05:39 AM
SRT6 Gang Member's Avatar
THREE 6S
https://www.crossfireforum.org/forum...ad.php?t=23022
Here is one way.
Old Apr 21, 2008 | 05:46 AM
magneticred's Avatar
I put in the Radio Shack (273-060) tone as described here:
https://www.crossfireforum.org/forum...ad.php?t=23009
It works great. I did place it just outside the fuse box in a small plastic bag for protection. It is louder outside the fuse box.
Old Jul 17, 2008 | 06:30 PM
OK everyone here is the official sound clip from the radio shack device
Turn up your sound.....
http://www.youtube.com/watch?v=URCocPE2Mpg
Old Jul 18, 2008 | 02:38 PM
CRM's Avatar
CRM
Is this not a standard feature on these cars? It is with Mercedes products using the same system. When I purchased mine, I noticed it did not "beep" as with most other factory systems. I soon found out that the main alarm horn had failed and the "beeping" feature was restored when I replace the main alarm horn.
Old Jul 18, 2008 | 10:34 PM
The Beep's Avatar
Sorry, I cannot be programmed.
Old Jul 19, 2008 | 07:03 AM
Rokypoky's Avatar
Where is the main alarm horn located at????????
Old Jul 20, 2008 | 06:23 AM
CRM's Avatar
CRM
In the raintray, between the engine compartment and the windshield. To the right of the windshield wiper motor.
Old Jul 20, 2008 | 09:46 AM
jonnyangel04's Avatar
I had problems with my alarm so I took it to chrysler, turns out I had a wire cut and they fixed it after ripping my whole car apart. Anyway when I locked the doors the yellow lights used to flash twice, now they hold for about three seconds, my unlock flash is the same. Point of the story I think chrysler can mess with the settings as far as lights and sound goes, but sound forsure has to be just that, a replacement of the alarm to the new 06 alarm horn.
tcar32909
Aug 1, 2024 02:41 PM
Reliableron
Oct 17, 2015 10:19 PM
eatmycrackers
Sep 23, 2015 09:08 AM
xjken
Sep 13, 2015 10:18 PM
