Squashed Oil Filter ?
Old May 5, 2008 | 08:35 AM
Chris2806126's Avatar
Default Squashed Oil Filter ?
Seems the last three times I've changed my oil filter the old one is all scrunched up when I take it out. Is this happening to others ?
I like to wipe out the housing when I change them also, but beware the theads on the housing like to slice your fingers.
I change them at 3500 miles as they are paper.
Old May 5, 2008 | 09:18 AM
Opticon's Avatar
Default Re: Squashed Oil Filter ?
Did you "pop" the filter into it's seat when you installed it?
Otherwise it will be sitting a tad low on the column and might twist/crush when you tighten the top.
I suggest using the fleece filters as they look more sturdy.
Old May 5, 2008 | 09:43 AM
danimal's Avatar
I agree....looks like it wasn't 'seated' in the cap before tightening.
Old May 5, 2008 | 12:40 PM
Choppers07's Avatar
The filter looks like it was compressed when it was installed. You should ensure that the filter is completly slid down on the shaft, most filters have a mark on the element to locate the correct depth.
Old May 5, 2008 | 03:48 PM
Iamfink2's Avatar
Also use the fleece filters as they won't twist and bend like the paper filters can.
Old May 5, 2008 | 10:36 PM
Idaho's Avatar
I agree with Opticon and danimal, I don't think you had the filer seated all the way into the cap. I have always used the pleated filters and have never seen them distorted.
Old May 6, 2008 | 05:50 PM
patpur's Avatar
Senior Member/Moderator
Chris I just did mine last Friday and no it wasn't squashed. I was surprised how dirty it was, I think it had about 3000 miles on it but it was in otherwise good shape. Replaced with a Mercedes fleece filter.
Pat
Old May 6, 2008 | 06:49 PM
modulator's Avatar
Banned
Torque... a mighty thing.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
