Shifter Knob question.
Old Jun 16, 2008 | 09:36 PM
rem-lor's Avatar
Default Shifter **** question.
Hi Guys,
I was going to go to the store tonight for some groceries.
I pulled up on the shifter **** to put it in reverse.
That's when the whole panel including the shifter **** and the leather around it came out all at once.
I tried putting it back on and it works fine.But when I pull up on it
It keeps coming out again, just like the first time.
I can still use it but I have to hold the base of it when I want to put it into
reverse again.
Any ideas as to what can be wrong?
Thanks
Old Jun 17, 2008 | 04:51 AM
BestTimesNow's Avatar
Default Re: Shifter **** question.
You need to tighten the compression nut. See this thread.
https://www.crossfireforum.org/forum...561#post248561
Old Jun 17, 2008 | 06:53 AM
62thunderbird's Avatar
This happened to me downtown Chicago. Stressful to say the least.
Whem mine came up and off, my wife found a pin on the inner boot. It was about an inch long, maybe 1/8" diameter. It locks the **** shaft onto the shaft coming out of the transmission shifter. Then there is a spring-loaded collar that snaps up to cover the ends of this pin, preventing it from falling out.
My collar was turned 90 degrees so it couldn't snap into place, so vibrations eventually caused the pin to work loose. Replaced the pin, snapped the coller into place and all is well.
Here's the page from the parts manual: notice the pin on item #2...
http://i76.photobucket.com/albums/j1...ns/shifter.jpg
Valk
Jul 12, 2021 09:49 PM
Charlesl
Sep 30, 2015 10:46 PM
Selbyl
Sep 22, 2015 09:31 PM
Big Daddy
Sep 10, 2015 10:21 PM
chturner
Aug 23, 2015 06:14 PM
