Anyone else having problems with electrical
Old Jun 28, 2008 | 12:36 AM
conkeeper's Avatar
Default Anyone else having problems with electrical
I have 2005 LE 6 speed. I have over 50,000 miles on it. Here is the problem, 4 times since it turned over 45,000, it would fail to start, or shut off while driving. 4 times the dealer said it was fixed. They have replaced the BRAIN, Modular, and other items. But i did not have to pay a penny for any of to be fixed. I just want to know if mine is the ONLY one having this problem, or are others?
Old Jun 28, 2008 | 01:47 AM
crossfirefun's Avatar
Default Re: Anyone else having problems with electrical
There's a control module problem and a crank sensor problem that has been written about here. Try looking for both of these subjects. Check for no start in the search.
Old Jul 16, 2008 | 05:26 AM
BANT's Avatar
Did it fix the problem? I have the same my 2004 wont start sometimes and cuts out when im driving.
Bant
Old Jul 16, 2008 | 11:21 AM
The Beep's Avatar
Can only guess, but a lost crank sensor signal will cause the problems you are discribing. You will be driving along and the motor will just stop. Or on start up, there would be no spark. I would be like loosing the coil on an old car.
Old Jul 17, 2008 | 11:38 AM
Chris2806126's Avatar
Had the same problem on an Ford torus SHO and it was the crankshaft sensor. hope it's easier to replace then the SHO.
My friend hade the same problem on a Buick. He had a water pump leak and it drained down onto the crank sensor.
I sopose if you spray off the engine a lot, the sensor could get wet and fail. The splash shield on the bottom of the Crossfire will help stop splashing from the road, so if you do an oil change make sure to put it back.
crossfireusa
Oct 28, 2015 12:03 AM
nataliefs
Oct 5, 2015 01:03 PM
skeet370
29
Sep 18, 2015 05:53 AM
RiderJC
Sep 7, 2015 11:19 PM
rdougc
Sep 5, 2015 10:30 PM
