Icing on windshield in summer...
Old Jun 29, 2008 | 01:21 AM
John Webster's Avatar
Default Icing on windshield in summer...
When I turn on the air conditioning I get ice forming on the outside of the windshield at the bottom. I have to run the wipers on intermittent to clear it. Is this common to Crossfires?
I've owned three other air conditioned cars and never had this problem.
Old Jun 29, 2008 | 03:19 AM
chuck65's Avatar
Default Re: Icing on windshield in summer...
The air hitting the inside of the window, with the air conditioning on, is so cold that the humid air on the outside condenses and freezes on the outside. Mine does the same thing. I guess it just shows you how good the air conditioner is on our Crossfires.
We had a maintainence forman at work that would explain that the water dripping off of the pipes in our shop during the summer as " the compensation dripping off the pipes caused by the high humility in the air. " Kind of the same thing.
Old Jun 29, 2008 | 06:39 AM
sccasrt6's Avatar
You're also not the only Formula Vee driver on this forum! (Caracal C-1, SEDIV SARRC series)
Were you at the 45th?
Old Jun 30, 2008 | 01:48 PM
sleeper's Avatar
your vent system is not totally closing the defrost door, sending cold air to the windshield. imo
Old Jun 30, 2008 | 02:41 PM
PhillySRT's Avatar
What he said
A friend of mine had this happen on his Mercedes E-class and that is exactly what was happening. They fixed the defrost vent, which was staying open a bit even when the winshield defroster was supposed to be off.
This is only compounded by the fact that the air conditioning system in the Crossfire could likely cool down a full-sized sedan with room to spare.
Old Jul 3, 2008 | 12:01 AM
I get the impression from the replies that this is not a common problem.
I suspect it's a result of the "Crossfire trained" mechanic spending an hour and a half trying to get the dead on delivery radio out through the back of the console before he discovered that it was designed to come out through the front.
The lack of heat to the footwell is probably the result of the same maltreatment.
oldbiff
Mar 19, 2023 11:37 AM
debradegiovanni
Sep 27, 2015 09:39 AM
waldig
Sep 17, 2015 10:35 AM
Vegaslegal
Sep 10, 2015 11:24 AM
williammt
Sep 6, 2015 11:23 AM
