Help! Urgent HID question
Old Aug 2, 2008 | 04:44 PM
TheDon's Avatar
Default Help! Urgent HID question
Hey guys,
I'm installing my HID kit and I cannot figure out where these red and black wires go. If anyone could point me in the right direction or attach a picture that would be great!
The wires
The back of the lights?
Old Aug 2, 2008 | 04:49 PM
racermp's Avatar
Default Re: Help! Urgent HID question
those red and black wires, are they on the ballast of the hid kit? if so, thats the negative and positive. you wanna take out the low beam buld (outer light) the connector that 2 wires on it, u can use those to connect to the 2 wires on the hid kit.
since it's aftermarket, if those hid ballast wires don't fit the stock plug, u can create a plug wires (break off the stock bulbs conectors and plug solder them onto the hid balast ones so u can plug in the ballast to the stock connector, or figre something out.
Old Aug 2, 2008 | 05:08 PM
TheDon's Avatar
So I took the low beams out and I see that there are two black wires connecting to the low beam? This is wear I'm lost? I'm not sure where to connect the red and black.
Old Aug 2, 2008 | 05:24 PM
TheDon's Avatar
Got it! Thanks race.
Old Aug 2, 2008 | 05:42 PM
MI1XFIRE's Avatar
Be careful, the low beam connector on the Crossfire has a total of 3 black wires:
The single black is the positive
the double black is the negative
Old Aug 2, 2008 | 10:54 PM
racermp's Avatar
plug and try, i've connected a few hid kits from different cars, polarity doesn't really matter (you can connect the red or black to either pos or negative). the ballast is just a step up transformer, just boosts voltage to 1k or something. diff for diff brands.
if you wanna match pos with pos and neg with neg, get a voltmeter (multimeter), touch the points on the stock plug, it should read POSITIVE 12 or so volts, connect accordingly to the pos and neg on the voltmeter
post pics of what they look like
Old Aug 3, 2008 | 07:23 AM
MI1XFIRE's Avatar
Thanks for the insight , have you ever installed HIDs on a XF?
or do you own stock in a fuse supplier company?
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
