Radiator Fan Fuse?
Old Aug 14, 2008 | 11:39 AM
racermp's Avatar
Default Radiator Fan Fuse?
Hey all, ok so my old fan siezed up, i just put in a new one, but it doesn't turn on,
i tested it manually with cables from the battery, it works. but the car starts to run hot when i sit at a light, the fan doesn't turn on.
i can't find a fuse in the fuse box left side. is there another fuse for this?
thanks for any help
Old Aug 14, 2008 | 03:45 PM
racermp's Avatar
Default Re: Radiator Fan Fuse?
ok all, i got a multimeter and tested the wires on the fan control module (well what i think is the fan control module), i tihnk it's the module on the left fender well, it's all grey metal fist sized, and i see the fan wires going to it.
it's getting one 12V all the time. when i turn on the car with a/c on, one of the small wires gets some voltage.
does this mean the module is bad?
thanks for any input
Old Aug 15, 2008 | 05:13 AM
patpur's Avatar
Senior Member/Moderator
I know there was a recall/TSB on the fan way back. I had mine done about 6 months after getting the car. As to what it is you are dealing with, sorry I'm not that tech oriented. Check the TSB section if you haven't already.
Pat
Old Aug 15, 2008 | 07:43 PM
racermp's Avatar
thanks. yea i looked there, not too much info. i think its the fan control module, im gonne try getting one tom
Old Aug 16, 2008 | 09:57 AM
Can't Drive 55's Avatar
Yeah, that is the fan"s PWM module (control) your looking at. My dealership had replaced it due to a recall or TSB before I purchased my Xfire. When they reconnected the fan to it they plugged it in reverse polarity. Boy did it make a lot of noise when it turned on
Anyway, it sounds as if that is what's gone bad since you are getting voltage to it. If it was a recall, your dealership (or any Chrysler dealership) should replace it for you.
Hope this helps.
Steve
Old Aug 16, 2008 | 12:41 PM
racermp's Avatar
hey guys, yeait was the radiator fan control module, i found one at a junkyard and replaced it this morning, all works well now.
thanks alot all
syfi
Mar 28, 2026 04:14 PM
Valk
Jul 12, 2021 09:49 PM
paine2907
Oct 2, 2015 10:01 AM
Oct 1, 2015 01:42 AM
Bob4kacz
Sep 16, 2015 11:20 AM
