Power Window Prolem
Old Aug 17, 2008 | 09:56 AM
tlppsp's Avatar
Default Power Window Prolem
Both power window "auto down" only works when it wants to. I can't find a comon reason for them to work one time and not another. Anyone have a fix?
Old Aug 17, 2008 | 10:00 AM
ichon's Avatar
Default Re: Power Window Prolem
Remove the center console and blow out the window key pads. If liquid or moisture got inside the console it can cause the window key pads to muck up. If that's not the problem then check the wiring for the windows.....a wire might be pinched.
Old Aug 17, 2008 | 10:04 AM
robby363's Avatar
Are you pushing the switch all the way down till you fell a click? If you are and they don't work it sounds like a bad switch.
Old Aug 17, 2008 | 10:06 AM
tlppsp's Avatar
Switched are clean and dry. The auto down feature may not work one timie and then they just start working and it may be days before it does it again.
Old Aug 18, 2008 | 06:19 PM
BRappaport's Avatar
I have the same problem with my Roadster. Individual window switches work fine. Top up/down switch when double-clicked only works sometimes to lower both windows together. I have not taken it to the dealer yet...but I have to believe it is a bad switch.
Old Aug 19, 2008 | 05:15 AM
tlppsp's Avatar
Default Re: Power Window Problem
My windows will not go "auto down" they travel some and just stop. You push the window switch all the way again and it does the same thing. Then on another occasion they work correctly. It's got me puzzeled.
Old Aug 19, 2008 | 07:42 AM
AlG's Avatar
AlG
The auto down feature has never worked on my '05 roadster. I just hold the switch down....is it that big of a deal?
Old Aug 19, 2008 | 08:09 AM
tlppsp's Avatar
You're right it's not a big deal. Thats one of the reasons I haven't taken it to the shop for repair. The other reason is it's intermitent and the shop (dealer) probally can't fix it if it's not doing at the time it's in the shop.The dealer in my area doesn't have Crossfire educated staff so what's the odds of getting a fix?
Valk
Jul 12, 2021 09:49 PM
Nexxus
May 8, 2016 04:43 PM
Apr 28, 2016 02:04 AM
nataliefs
Oct 5, 2015 01:03 PM
Valk
Sep 17, 2015 11:43 AM
