Check engine light?
Old Dec 21, 2008 | 07:09 PM
Chris L.'s Avatar
Default Check engine light?
Zero degrees today......pulled in garage.....30 min later left again.......serpentine belt now running to the max(constantly) .......& eventually check engine light came on???? Anybody run into this before?
Old Dec 22, 2008 | 12:56 AM
tighed1's Avatar
Default Re: Check engine light?
Don't understand the question.
Are you saying that the supercharger is constantly engaged?
Old Dec 22, 2008 | 12:58 AM
tighed1's Avatar
Ok just went to your gallery. Not an SRT.
Now I'm really confused!!!
Old Dec 22, 2008 | 02:54 AM
REVIT93RX7's Avatar
Don't understand what you are asking?
Old Dec 22, 2008 | 05:28 AM
Zero degrees today......pulled in garage.....30 min later left again.......serpentine belt now running to the max (constantly)
Please explain ????
Old Dec 22, 2008 | 09:10 AM
Chris L.'s Avatar
The fan belt.....was turning so fast I could even hear it when I was driving.....& the check engine light eventually came on.
The dealership just called.....said it healed itself (religious overtone?)??? .......suggested it may have had something to do with the mass air flow sensor & zero degree temp outside (+ I was going over 100mph on I-70 just before it happened)....
Wonder what the wind chill is at 100mph / 0.0 F ?
Maybe I should slow down at these temps.....
Old Dec 22, 2008 | 10:51 AM
maxcichon's Avatar
Wind chill is a measure of evaporative effects. Has no effect on machinery, only living things. Even democrats!
Old Dec 22, 2008 | 11:27 AM
downwardspiral's Avatar
how can a fan belt turn faster than its supposed to?
Old Dec 22, 2008 | 11:41 AM
[quote=Chris L.]
Wow, religous overtones, maybe we should take up a collection.
Old Dec 23, 2008 | 06:22 AM
MikeR's Avatar
I am pretty sure the fan belt cant go any faster than the crank shaft.
MikeR
Old Dec 23, 2008 | 06:30 AM
007_MI6's Avatar
MikeR
Well, if you find one that does, get a short one, bypass the crank, and let the belt run the acc. by itself.
Old Dec 23, 2008 | 06:36 AM
Stogey's Avatar
Hmmmmm, very interesting ! Guess I'm gonna have to watch for belt overspeed at 100mph from now on !
Old Dec 23, 2008 | 06:54 AM
With Chris L's references to serpentine belt and fan belt, could it be that he heard the electric fan running all the time and had assumed it was run by a belt.
Not everyone spends their days with their head stuck under the hood, some never lift the hood at all.
Old Dec 24, 2008 | 02:14 AM
Chris L.'s Avatar
I think you hit it on the head......(didn't fans used to run off belts?)
Regarding wind chill.....I know the term applies to flesh.....but I can't help but think that zero degree air moving at 100+ mph is going to pull more heat away from an inanimate object faster than zero degree air standing still.......
P0112 Intake air temp sensor, stored code ....
In any case.....she's running like a striped-***-ape again!!
Old Dec 24, 2008 | 06:09 AM
Go to this site and look at section 7.7 (cooling) It explains what could be wrong and causing the fan to run constantly.
2004 Crossfire Service Manual [84MB]
Old Dec 24, 2008 | 11:48 AM
Chris L.'s Avatar
Oh, when I said she was running like a striped-*** ape again......I meant the car in general....not the fan...everything seems to running correctly again.....
God I love this car!!!!! Even fun on ice!!!!
Hoppy
Dec 7, 2018 07:36 AM
jgreen
106
Sep 18, 2017 11:46 PM
spoiler
Sep 2, 2015 08:56 PM
axnguyen
Jul 21, 2015 11:41 AM
Mark McKay
Jul 17, 2015 01:18 PM
