Newb Questions
Old Feb 13, 2009 | 09:59 AM
AllEuro's Avatar
Default Re: Newb Questions
Originally Posted by Tidus532
Wow went to school in gettysburg? Gettysburg Area im guessing. Thats cool.
I am assuming by gettysburg area you mean Gettysburg high school? I actually went to Gettysburg College. Fun times!
Old Feb 13, 2009 | 10:56 AM
Paul Bosslet's Avatar
Hi,
Virtually all mercedes headlight switches have this "double pull" fog light feature, but I don't know how far the wiring is completed for the rear fog light on U.S. bound Crossfires. The thread provided above has alot of good info though!
Old Feb 13, 2009 | 08:57 PM
Tidus532's Avatar
Sorry i meant Gettysburg Area as in not upper adams because some people consider that gettysburg and its actually bigglerville. Anyways thats cool my brother graduated from there in 2007.
Old Feb 13, 2009 | 10:32 PM
jlvm's Avatar
Originally Posted by 007_MI6
1) The -33700 is how many past the service interval you are. Service A=Single Wrench Service B=Double Wrench. Switching types at each mileage interval. This may help https://www.crossfireforum.org/forum...rvice+schedule Here is a link to the digital copies for you manuals.https://www.crossfireforum.org/forum...ad.php?t=13875 Either the work wasn't done or it just wasn't reset at each service. There is a thread around to reset, just do a search for the FSS reset.
2) The radio is supposed to stay on for about 5 seconds after you turn the car off, and will stay on for 30-60 minutes (can't remember exactly) if you press the power button before those 5 seconds are up.
3) When you close the doors the parking and fog (if you have them) lights will come on for a few seconds before going off.
4) The lights are probably the switch. If you turn it to the left there are two extra positions for European cars. One for the left only parking lights and one for the right. If you have fog lights, there is also a second pop out, after the fog light pop. Also for European cars that would activate the rear fog lights, not available on our models.
There, I think I made sense in that.
Only the left one is a fog light. The right one is the reverse. Anyone knows why in Mexico we got American Coupes and European Convertibles? Knew it when I changed the coupe for a convertible. Weird
Old Feb 14, 2009 | 07:02 AM
Tidus532's Avatar
Wow, that is weird intersting..
Old Mar 1, 2009 | 11:07 AM
jgreen's Avatar
Here is the process to reset the FSS if you need to. I got it first try, but I have heard it can be really tricky.
RESETTING THE FSS MAINTENANCE INDICATOR AFTER AN OIL CHANGE
1. Move the ignition switch to the “RUN” position.
2. Within 4 seconds of moving the ignition switch into the
“RUN” position, press the reset button for the trip odometer
twice within one second. The display for the FSS service
request is activated for 10 seconds
3. During the 10 seconds the FSS service request is displayed,
move the ignition switch to the “OFF” position.
The FSS service request will continue to be displayed.
4. Press the reset button for the trip odometer and hold.
5. Move the ignition switch to the “RUN” position
6. Continue to press and hold the reset button for the trip
odometer (about 10 seconds) until the audible signal
sounds and the new start distance appears in the display.
The tool symbol should disappear at this time.
Hi Thanks for the information, When I did my first oil change (at 2,260) I reset the FSS but, now its shows 2 wrenches and 7000?? why?
Old Mar 1, 2009 | 12:59 PM
danhaman's Avatar
Mine says -730 with a double wrench, but it doesn't change. I expect if it was miles past my due service it would keep track as I continue to drive on.
Thanks
dh
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
