Fog Light Lamp Removel
Old May 17, 2009 | 11:46 PM
Crossfire725's Avatar
Default Fog Light Lamp Removel
what is the easiest way to remove both fog light lamps completely
thank you for you time
Old May 18, 2009 | 08:11 AM
bluecoupe's Avatar
Default Re: Fog Light Lamp Removel
Fog lamps may be accessed via the small plastic door in the forward surface of the wheel well splash shields. I believe you'll need an 8mm socket to remove the 3 nuts holding each one on. Easier if you remove the wheel first. Good luck! Oh and be sure when you close the access door it is secure otherwise you'll be replacing it after it has rubbed away against the tire surface......believe me I know!
Old May 18, 2009 | 09:44 AM
thank you soo much. good reminder!
Old May 18, 2009 | 09:58 AM
nate_man's Avatar
Already lost one and need to probably get a pair. Any idea on how much they are?
Anyone done some of the extra work to keep em secure and not dissappear since they seem to be famous for this!
Thnx
Old May 18, 2009 | 10:01 AM
bluecoupe's Avatar
Thnx
They're less than $7 apiece. When I ordered mine, I got a spare, just in case!
Old May 18, 2009 | 10:05 AM
nate_man's Avatar
THnx. I will need to do the same. I am sure that I am getting dirt buildup in there! LOL!
xfireohio
Jul 20, 2020 12:03 AM
Adrian_X
Nov 9, 2017 08:49 AM
maxcichon
Jul 8, 2016 08:28 AM
pioneer4x4
Sep 24, 2015 11:17 AM
KwehCat
Jul 16, 2015 04:48 PM
