Cruise Control problem
Old Dec 6, 2019 | 04:58 PM
ebmcculley's Avatar
Default Re: Cruise Control problem
In all other cases, there appeared to have been some other indication of a problem, in addition to the cruise control not working. But you have indicated that the brake light switch CAN operate the brake lights properly and still have adverse effects on other items. So replacing the brake light switch is the first logical and inexpensive step.
Old Dec 6, 2019 | 10:00 PM
zip439's Avatar
That is correct. The brake light switch has solved the wing and ESP/ BAS light for several of us. Hope it is helpful for you, but I can not be certain.
There are wiring diagrams in the service manual. You may want to look them over. click here to download if you need one click: 2005 NA and SRT6 service manual
Thank you to 180 and Timelord
Old Dec 7, 2019 | 12:21 PM
If all else fails, stick one of those cigarette-lighter voltmeters in and watch it when you drive. If voltage varies a lot, I'd suspect alternator or battery.
If fact, I replace my battery at four years. Your battery is your electrical system's filter - and these car's various modules seem to be REAL fussy about how well the B+ feed is filtered.
Old Dec 7, 2019 | 12:33 PM
The brake switch is in the Cruise Control circuit, touch the brakes and CC switches off immediately. There are more contacts than just contacts to the brake lights on the brake switch.
Old Dec 7, 2019 | 02:05 PM
ebmcculley's Avatar
Well, the good new is I was able to get all of the under dash panels off, replace the brake switch and get it all back together (with no screw left over) and everything is working correctly, except the cruise control. At least I know it's not the brake light switch.
Re: Battery, I installed an inexpensive after market TPM System, as there wasn't even a TPMS light showing on dash at start up. The unit plugs in to the cigarette lighter shows voltage 14.2 tor so while driving without much variance. Battery is less than 6 months old.
Thanks for all the help, but we will probably just live without Cruise Control unless something else pops up. We don't expect to take it on long trips anyway, it's my wife run around town car.
Old Dec 8, 2019 | 09:38 AM
zip439's Avatar
Does the TPMS warning light go on when you first turn the key to start and all the instruments lights turn on as a test just before starting the engine? It is located on the left side at the top of the other warning lights. If it's not showing then a previous owner disengaged it. It will never light if the GY/YL wire in the overhead cabin light has been moved from it's number two position on the connector to the blank number 6 position. See post #3 click here
Old Dec 8, 2019 | 11:26 AM
ebmcculley's Avatar
The light does not ever go on, so I suspect you are right, it has been disabled. I'm not worried about it as the new TPM System I have works fine. Unless, having the original TPM System disabled, could in some way cause the cruise control to not function. Then it might be worth investigating.
Old Dec 8, 2019 | 12:35 PM
Any codes show up, the CELdoes not have to be on to Have a code set.
Speed sensor failures can cause this problem.
There will be methods in the Service Manual for checking the system.
Old Dec 8, 2019 | 07:59 PM
….. Unless, having the original TPM System disabled, could in some way cause the cruise control to not function. Then it might be worth investigating.
No, this has absolutely nothing to do with your CC not working. Totally separate system with no interconnectivity.
Old Dec 8, 2019 | 08:16 PM
ebmcculley's Avatar
Thanks for the precise and specific response!
That was my impression after reading all of the posts requesting info on disableing the TPMS with no mention of potential side effects!
Old Dec 8, 2019 | 08:22 PM
ebmcculley's Avatar
No scanner so no codes. Not sure what CEL stands for - Check Engine Light?
I will research the speed sensor question.
Old Dec 9, 2019 | 10:34 AM
no scanner so no codes. Not sure what cel stands for - check engine light?
Bingo ........
Old Oct 2, 2020 | 06:17 PM
jshafty7's Avatar
I’m having exact same CC issue… It holds under 70 mph but nothing above… Has anyone found a solution…?
KDW4Him
18
Sep 1, 2021 05:47 PM
xfClifford
Mar 3, 2021 04:52 PM
waldig
Sep 2, 2015 11:02 AM
PNA
Car Shows
Aug 3, 2015 08:22 AM
PNA
Crossfire Events and Meets
Jul 13, 2015 11:40 AM
