Name of Original battery???
Old May 28, 2009 | 07:13 PM
Mr. Burns's Avatar
Default Name of Original battery???
Hello, Everyone--
I've owned my '05 limited for about 6 weeks now and considered replacing the battery now that the car is about 4 or 5 years old. A quick check under the hood informed me that the battery is an "Exact-Fit" brand. I'm assuming this is a replacement battery for I've seen this brand advertised at my local Merchants Tire and Auto. Any thoughts?
Monty
Old May 28, 2009 | 07:45 PM
rakoom2002's Avatar
Default Re: Name of Original battery????
I could be wrong but I believe the OEM battery is "Super Awesome Deluxe Long Life Goodness Battery" brand battery. Can anyone confirm that?
Old May 28, 2009 | 07:51 PM
It's more like "I Will Leave You Stranded After Four Years" brand battery. I could be wrong.
Old May 28, 2009 | 08:12 PM
07bluezx14's Avatar
I'm not sure of the exact size off of the top of my head, but if you do a search, you'll find many different options, as far as brand. I have a svr yellow top due to audio upgrades, group 34 seems to come to mind. chris
Old May 28, 2009 | 08:13 PM
07bluezx14's Avatar
see my sig.
Old May 28, 2009 | 09:25 PM
Originally Posted by Mr. Burns
Hello, Everyone--
Monty
The original battery was a white cased Varta, a European brand. Varta is owned by Johnson Controls who make an identically equivalent here in North America and sell it as an Interstate battery.
Go to this thread for all to be revealed.
https://www.crossfireforum.org/forum...placement.html
Old May 29, 2009 | 04:01 PM
Sandgrounder's Avatar
I replaced mine yesterday,the old one was a Mopar PRO 6, built in 05, id 48-4800-8.Replacement is a Canadin Tire 4800 serries,same battery fits in todays 1/2 ton Chev. paid $110 CAD, PLUS TAX AND CORE. Its a perfect fit and has the same vents comming off the side. 3 year free exchange plus 6 years limited warrentywas quoted $260 cad @ dealership
Old May 29, 2009 | 05:34 PM
You mean Chev don't use the side terminals anymore in their vehicles?
James
Old May 29, 2009 | 05:46 PM
James
He said that it had the same side vents, he did not mention side terminals. Canadian Tire batteries have side and top terminals normally on all their batteries.
Old May 29, 2009 | 06:52 PM
Side ventxs to off gas or fluid, no side terminals just the top posts
Old May 29, 2009 | 07:11 PM
[quote=Sandgrounder]I replaced mine yesterday,the old one was a Mopar PRO 6, built in 05, id 48-4800-8.Replacement is a Canadin Tire 4800 serries,same battery fits in todays 1/2 ton Chev. paid $110 CAD, PLUS TAX AND CORE. Its a perfect fit and has the same vents comming off the side. 3 year free exchange plus 6 years limited warrentywas quoted $260 cad @ dealership[/quote
Sandgrounder, I asked at Crappy Tire if they had a battery that fit the Xfire and I was told that they did not have one. I suppose he looked in the computer and it was blank, I did not bother to pursue it as I could see that I was dealing with a chump.
I wrote the thread on OEM battery replacement and I wanted to add a Can Tire battery if possible.
Could you answer a few questions so that I can add it to the thread?
It is the same size length x width x height Yes or No?
Does it require a spacer under the clamp?
Cold Cranking Amps (CCA) ?
Cat # ?
Thanks
Old May 29, 2009 | 09:14 PM
Goldwing's Avatar
Name? I call mine Sparky.
Old May 29, 2009 | 09:32 PM
velociabstract's Avatar
It was made in Spain. It's called una bateria.
Les
Old May 29, 2009 | 09:41 PM
SRT6-Man's Avatar
Hello, Everyone--
Monty
Just put in new Batt, Interstate Battery Mega tron plus, 85 month, Part# MTP-H6.. Direct fit, perfectoo....When the stock batt go's it go's.....no warning!!
Old May 31, 2009 | 12:13 PM
180, Mastercraft Eliminator
Part/ product # 10-8400-8
Cold Crank Amps 690 @0f
Cold Crank Amps 820 @32f
Identical in size
Same spacer under the clamp
Top mounted terminal posts
Ser # 4767247
Old May 31, 2009 | 03:30 PM
Identical in size
Ser # 4767247
Thanks for the info, two more questions though.
In your first post you said it was a series 4800 which would seem correct (#48 battery size) now you say its a 8400?
You say same spacer under clamp, do you mean the rubber pad that is snapped between the clamp wires, or there is a loose spacer?
The original just uses the attached pad.
I will add it to the list and maybe buy it myself as my battery was made in 2003, I may be hanging by a thread with it.
Old May 31, 2009 | 04:16 PM
green-ghost's Avatar
A 34/78 fits in the crossfire?! Any clearence issues?
Old May 31, 2009 | 04:51 PM
180,
typo should be - 10-4800-8
Spacer is the rubber pad between the clamp wires
yes replace it , hanging by a thread on QEW or 401 is not a good Idea
Reliableron
Oct 17, 2015 10:19 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
Idrenak
Sep 19, 2015 08:17 PM
BlackJax-SRT
Sep 18, 2015 07:03 PM
Valk
Sep 17, 2015 11:43 AM
