Turbo/Supercharging Basics by Chuck
Old Jun 30, 2009 | 05:32 PM
ChuckNorris's Avatar
Default Turbo/Supercharging Basics by Chuck
Since I am no longer pursuing any kind of kit for the Crossfire I figured its about time to unleash what I know onto the forum so a few of you interested can experiment with the car. I shall not be liable for any catastrophic damage that may occur from the following procedures, do this at your own risk! Nothing in this thread pertains to the SRT versions
First of all force inducting the NA Crossfire is very much like force inducting any other naturally asperated vehicle with only a few exceptions.
We all know that the mechanicals of doing this are no major challenge so I am going to skip ahead to the basics of the tuning problems.
I'll call them Chucks 8 Commandments
  1. Thou shalt hide boost from the ecu. This can simply be done by voltage clamping the MAP sensor to about 3.75volts. This may vary from car to car and current elevation. You can obtain an atmospheric reading from the map sensor with the ignition on and the engine not running with a voltmeter.
  2. Thou shalt not produce boost at a throttle position lower than 15 degrees. If the Ecu calculates a large enough amount of air entering the engine via the MAF, MAP, and IAT at throttle positions lower than 15 degrees it will register a fault and cut fuel. So to make a long story short you must use a bypass valve. This also keeps the car from fuel trimming in closed loop mode(because of boost it can't read) at low throttles and cruising. This is the only solution to keep your Crossfire driving like it did from the factory.
  3. Thou shalt regulate fuel under boost. You can do this with a rising rate fuel pressure regulator or your favorite MAP based extra injector controller. If using a rising rate fuel pressure regulator it is important to remove the factory regulator/filter and use a 3 bar fpr w/larger injectors. To put it simply, use a lower base pressure and larger injectors and the rising rate regulator. You may ask but Chuck whats the point in that? Well most RRFPR's are designed to work with 3 bar(43.5psi) base fuel pressure not our 58-60psi stock pressure. It won't raise the pressure until there is enough clamping force to overcome the base. Using an 8:1 rrfpr the pressure would not rise until almost 2 psi of boost are applied to it. Doesn't sound like a lot but lean is lean.
  4. Thou shalt control timing. There are lots of companies that make piggybacks for this and until one of them sends me a fat check I'm not going to endorse the use of any of them. But we all know, at least us nerds that read all the forums, that Splitsec.com has a compatible programmable piggyback for this.
  5. Thou shalt keep the MAF close to the throttle body. Unless you want to experience some real throttle lag, and not the imaginary kind the Sprint booster is supposed to fix(what a joke lol ).
  6. Thou must use a MAF altering piggyback. This is for fine tuning the fuel trim in open loop. The ecu easily handled the closed loop fuel trims to stoichiometric.
  7. Thou must monitor AFR. I used an Innovate LM1 wideband which also emulated the narrowband right out of the box. I got the best results around 12:1 AFR's.
  8. Thou shalt use an intercooler. I used Methanol/water injection. With 10:1 compression ratio I think this is the most important part and will provide the most protection for your engine as well as power.
Hiding the boost was the most important part of this whole project because Mercedes being one of the smartest companies on the planet electronically safeguards their drivetrains in a variety of ways. This is meant to be a simple list of inexpensive ways to FI the crossfire and I'm sure there are a lot of other ways to tackle these problems. I still have lots of .5 inch waterjetted intake flanges if anyone wants to build their own intake manifolds PM me.
Old Jun 30, 2009 | 06:07 PM
tighed1's Avatar
Default Re: Turbo/Supercharging Basics by Chuck
Don't have a NA Crossfire Chuck but appreciate you posting the information for others to use.
Thanks!
Now the rest of you, get out there and get BLOWN!
Old Jun 30, 2009 | 09:46 PM
nox1s's Avatar
.. I was saving all my money up for this kit!!!
Oh well.. TVT265/300 here I come I guess...
Old Jul 1, 2009 | 09:54 AM
Any decent speed shop should be able to hook you up with the info here. I hope someone uses a procharger or something similar. No reason why you can't have SRT power with that.
Old Jul 1, 2009 | 12:10 PM
downwardspiral's Avatar
What kind of bypass valve are you talking about in number 2? I would think it would be tough to get a blower not to make boost below 15 degrees on the pedal.
Old Jul 1, 2009 | 01:03 PM
Its just a butterfly valve that connects the intake and output side of the supercharger that is controlled by a sprung vacuum diaphram. Changing the spring regulates at what vacuum level the valve closes. I used the diaphram from the tbird the sc came off of. There are aftermarket bypass valves out there though.
Old Jul 1, 2009 | 01:07 PM
Not 100% sure but I believe a blow off valve connected properly will function the same.
Old Jul 2, 2009 | 01:47 AM
BlueStorm's Avatar
why not just skip all this funny bussiness and use the srt6 ECu, the v8 converion thread seemed to have succesfully transplanted a v8 into a v6 benz. this seems like the way to go assumingthe NA's eprom can be transferred into srt6 ecu so the car recognizes the vin code.
Old Jul 2, 2009 | 10:30 AM
Seems like the smartest way to go to me as well. Lack of knowledge and software led me to do what I did. The total cost my way is under $2k pending what sc or turbo you use if you install and fab everything yourself.LET is supposed to be able to reprogram fo FI. It just takes someone with the motivation to find the details and bring it to the forum. My crossfire is going back to stock and getting traded in soon so it won't be me. My wife needs a SUV. Maybe a ML320.....
MiamiTVR
Other Vehicles
Nov 11, 2015 12:36 AM
o55ie18
Oct 5, 2015 05:50 PM
Charlesl
Sep 30, 2015 10:46 PM
pop49
Sep 30, 2015 11:14 AM
Sep 28, 2015 07:40 PM
