Xccelerated Performance Stage 1 clutch
Old Oct 1, 2009 | 07:16 PM
DarkhelmetRT's Avatar
Default Xccelerated Performance Stage 1 clutch
will be in the road testing phase in the next couple weeks. should be capable of handling 330 ft lb of torque with stock pedal effort. more info to come
Old Oct 2, 2009 | 01:15 AM
newCrossfire's Avatar
Default Re: Xccelerated Performance Stage 1 clutch
AWSOME! are we still going to be within our $500 budget?
Old Oct 6, 2009 | 10:13 AM
Nope. the clutch on these things is a very different design than most normal clutches. best I can do is $879. but considering that it will handle more than 100hp over stock and costs less than the spec crap I don't think it's that bad. if there is interest I may put a group buy together and save people some money, but noit until the testing phase is complete
Old Oct 6, 2009 | 11:07 AM
What, exactly, does the $879 cover?
Old Oct 6, 2009 | 11:52 AM
Disc and pressure plate
Old Oct 6, 2009 | 12:57 PM
TVT_DESIGN
Guest
Posts: n/a
I'm pretty sure the SPEC clutch is about 1100 for all stages up to 3. If you could get a GB to save even more that would be perfect.
Old Oct 6, 2009 | 10:51 PM
$879 is very fair. i was originally quoted a bit a over $700 for the oe from the dealer but i know you can get them for under $500. Group buy would be great tho! let me know when your ready to sell these babies! im in!
Old Oct 7, 2009 | 06:54 AM
Probably about a month. I want the tester to get at least 1000 miles before I release them.
Old Oct 7, 2009 | 08:08 AM
Will we have to replace the flywheel at the same time? Anyone have pricing on this?
Also, has any research been done on the clutch delay valve? I used to have a bimmer and due to the CDV it made shifts horrible, made the modification, made it a new machine. I am not certain there is one in the XF, but it sure feels like it. Here is some additional info from some bimmer guys. I have been told these are prevalent on Euro cars....
CDV
Old Oct 7, 2009 | 08:17 PM
CDV
should be able to resurface your existing flywheel. and I'm not sure about the CDV
Old Jan 24, 2010 | 02:12 AM
updated information please!
Old Jan 25, 2010 | 11:45 AM
Dark, you still around? I knew at one time you had a feeler out to sell the coupe, just seeing if you were planning on still having these perf clutches done or if you had let it die. Thanks.
syfi
Mar 28, 2026 04:14 PM
Oct 1, 2015 01:42 AM
Ralph289
Sep 21, 2015 09:34 PM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
