TPMS light coming on and staying on.
Old Oct 5, 2009 | 12:41 AM
cheap ride's Avatar
Default TPMS light coming on and staying on.
With the climate change and a drop of temp along with that it is time to see the TPMS light remain "on" after it runs the diagnostic test. It happened last year and nothing has changed. I was over in Seattle last week when the light stayed on. A local Les Schwab checked and adjusted the pressure on all four tires for FREE. Problem solved!
Get an accurate pressure gauge and read the pressure on all four tires. Set them to the door-post figure of 32 front and 33 rear and the light will go out and remain out until Mother Nature gets into the act again--or you have a genuine problem.
Jim
Old Oct 5, 2009 | 09:02 AM
Choppers07's Avatar
Default Re: TPMS light coming on and staying on.
Or until you adust your tire pressure. Mine are so sensitive that if I add 1 lb to any tire they trip.
Old Oct 5, 2009 | 09:17 AM
Keep all four at 35# and you will be OK.
Old Oct 5, 2009 | 10:02 AM
ZAHANMA's Avatar
+1
This is what I do too....until I go to the track...then the psi isn't good until the TPMS light DOES come on haha.
Old Oct 7, 2009 | 08:45 PM
07bluezx14's Avatar
mine stays on, even if All tires are within specs.
Hoppy
Dec 7, 2018 07:36 AM
wruss
Feb 8, 2017 01:05 PM
northwest_crossfire
May 30, 2016 05:19 PM
Mark McKay
Jul 17, 2015 01:18 PM
2004_
Jul 11, 2015 03:14 PM
