Coolant Level on recovery tank?
Old Oct 10, 2009 | 02:41 AM
BRappaport's Avatar
Default Coolant Level on recovery tank?
Where is the coolant level indicator mark on the coolant take? ( Cold level mark when full ). I can not find it. I know there is a low coolant level sensor...but is there a visual indicator level on the tank some where?
Thanks
Old Oct 10, 2009 | 08:17 PM
magneticred's Avatar
Default Re: Coolant Level on recovery tank?
My tank doesn't have a level marker on it either. I would fill till it is about 2 inches (5cm) from the top, since that is where mine has always been since new.
Old Oct 11, 2009 | 06:11 AM
danimal's Avatar
Looking into the coolant tank, you will see a plastic 'fin' on the inside (upper left corner when standing by the fender). The coolant should come to the top of that 'fin' which is about an inch or so below the cap. Overfilling can actually cause overheating issues.
Old Oct 11, 2009 | 08:21 PM
BRappaport's Avatar
Thanks....Mine is a 1/2 inch or so below that mark. I am trying to figure-out weather or not I am loosing coolant. Every time I start my car, and the fan is on...I smell the sweat smell of coolant for about the first 30 seconds of operation. Any thoughts?
Thanks
Old Oct 12, 2009 | 05:51 AM
danimal's Avatar
Bring it up to the top of the mark with some distilled water and keep checking it every few days if it is your daily driver. If it isn't dropping, then I wouldn't worry too much about it. It's possible some could have come out the overflow, giving you that 'sweet' smell for a few seconds.
Old Oct 14, 2009 | 01:19 PM
By fin do you mean the white post thingy that sticks out horizontally from the rear end of the tank or the black bead that runs around the inside of the tank. No matter really as they are on the same level. That is a good level to keep it at even though I can find no mention of the indicator in the manual etc. But I think the white post is the indicator.
If you use the word fin some people will start looking for a small fish in the tank.
Old Oct 16, 2009 | 08:29 PM
BRappaport's Avatar
Thanks everyone for all the replies.
If the fin or Black rubber is the fill height...does anyone know what the min level is that triggers the sensor?
syfi
Mar 28, 2026 04:14 PM
minimayhem
16
Aug 23, 2016 07:47 AM
paine2907
Oct 2, 2015 10:01 AM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
suelo
Sep 18, 2015 05:01 PM
