Small light in passenger headlight assembly burned out. How do I remove it?
So the small light in the upper left hand corner of my passenger side headlight assembly has burned out. I looked at it and see that I cannot get to the bulb without removing the headlight assembly. There are two screws at the top of the assembly that I took out then I tugged on the assembly a bit but it did not come out. I don't want to break anything! Is there another screw somewhere? How am I supposed to get this darn thing out?
Thanks
Thanks
I was able to change both sides of mine with just my fingers. I changed them to amber from clear. Very tough but not impossible. Max uses medical type needle nose pliers to rotate the bulb sockets to remove and reinstall.
James
James
James
James
There are 4 bolts that hold the headlight assembly in place. Two on the bottom and two on top. Even with the bolts removed I suggest removing the bumper cover bolts on the sides to allow some extra leeway when manipulating the headlight to remove without scratching or breaking anything. Like Max I have a pair of long needle nose pliers that have a 45 degree bend. This helps turn the fittings. Once you have them out I suggest adding some lubricant to the rubber seals, this will make them easier to turn next time. Good luck!
i used a right angle needle nose pliers. maby a regular one will work. if u cant reach the buld slightly tryto turn the wireing harness coming off the buld it ushually breaks it loose
tom2112
Jul 12, 2015 04:41 PM
gtjl
Jul 8, 2015 07:42 AM
joethejeweler
Jul 7, 2015 08:58 PM
