how often to change the Cabin air filter ?
Old Nov 20, 2009 | 08:27 PM
brewski's Avatar
Default how often to change the Cabin air filter ?
How often are you to change your cabin air filter?
Old Nov 20, 2009 | 08:31 PM
Default Re: how often to change the Cabin air filter ?
25000 miles or sooner if needed........... instructions
Old Nov 20, 2009 | 08:56 PM
MikeR's Avatar
According the B service check list, you should change the cabin filter and fuel filter. I just did the B service on my SSB and got new filters for it. The Aero is next...
Old Nov 21, 2009 | 02:23 AM
NYPD-Crossfire's Avatar
When it starts to STINK inside the car!
Old Nov 21, 2009 | 10:47 AM
AllEuro's Avatar
That's not true for the na cars. The cabin filter is changed at service B and the air/fuel filters are changed every 4 years or 60k miles--that's what my owners manual said.
In relation to this thread, I just changed my cabin filter at 17500 miles. I replaced it with a Mann filter but I'm a bit disappointed buy it. The stock filter is a very stout item and the supposed OEM replacement is flimsy paper/cotton. The stock item is the exact reason I like German cars--they over engineer everything and that is demonstrated in simple items like the cabin filter.
Old Nov 21, 2009 | 02:21 PM
Marine05's Avatar
OK, so where exactly is the cabin air filter? I laid across the passenger side door sill this morning (not easy for a guy at my age) and pulled down the panel behind the glove compartment. I now know where the fan motor is, but did not see where the filter is. Can someone point me in the right direction?
Thanks,
Glenn aka Marine05
Old Nov 21, 2009 | 02:54 PM
MikeR's Avatar
It is just left of the fan access. Same method of sliding the latches and drops the door. Then you just pull the filter down and out.
Go to this thread and look at picture #3. You will see the cabin filter door on the left with the X marked on it.
https://www.crossfireforum.org/forum...installed.html
Old Nov 21, 2009 | 04:01 PM
So where are you guys buying your filters and how much?
Old Nov 21, 2009 | 04:46 PM
Marine05's Avatar
Thanks!!! I was so close, but yet so far
Old Nov 21, 2009 | 05:48 PM
MikeR's Avatar
I got mine from RockAuto.. WIX cabin filter $17 and WIX fuel filter $41. I am not impressed with the WIX cabin filter as it has the flimsy paper frame instead of the sturdy plastic frame. The BOSCH standard or activated charcoal areonly a couple of $$ more and look like (from the online pic) they have the plastic frame. It probably dosent make a bit of difference, but........
Old Nov 25, 2009 | 12:18 AM
+fireamx's Avatar
Not a Crossfire, but I wonder if I could persuade her to change my filter.
YouTube - How to Change Cabin Air Filter - Easy DIY Guide
Old Nov 25, 2009 | 01:53 AM
GDrag's Avatar
I changed mine in about 10 minutes. You will see a rectangular lid covering the cabin air filter, and i believe 4 latches or 2 that you have to move to the side to open. I changed mine out at 50,000 miles when it started to smell like a humid hot mess. haha
Old Nov 25, 2009 | 04:02 AM
FUBU's Avatar
OEM part# ?
Old Nov 25, 2009 | 06:18 AM
VQ35DE's Avatar
Shame on you Mike !
Old Nov 25, 2009 | 06:58 AM
paul1612's Avatar
good quality filters available from CarQuest
particulate filter part # 8977
carbon filter part # 90065C
Old Apr 18, 2010 | 02:20 AM
firemen's Avatar
Once a year you should change your car's cabin/pollen filter because if you don't your demisters will not work properly and the air inside your vehicle will not be very fresh especially when you used an acc cabin filter.
Old Apr 18, 2010 | 07:52 AM
VIPER0076's Avatar
I changed mine at 40,000. I could'nt believe the "CRAP" that fell out when I pulled the filter out. Lots of pine needles and stuff.
Old Apr 18, 2010 | 09:25 AM
Beaner's Avatar
Originally Posted by VIPER0076
... I could'nt believe the "CRAP" that fell out when I pulled the filter out. Lots of pine needles and stuff.
I almost changed mine once. I opened it up, a bunch of "stuff" fell on my floormat so I quickly closed it. Never to be open again!
Old Apr 18, 2010 | 10:05 AM
For some reason Beaner, I want to believe that...lol
Old Apr 18, 2010 | 05:21 PM
blackcrossfire07's Avatar
Changed mine after 4 years and 50K miles. It wasn't even in bad shape. Just had a couple of leaves in it. I also changed the engine air filters at the same time.
I didn't even know it had a cabin air filter until I started reading about in on this forum.
