Beware Metal Valve-Stem Caps!
Old Jan 15, 2010 | 11:32 AM
NYPD-Crossfire's Avatar
Default Beware Metal Valve-Stem Caps!
I just got back from my trusted MB dealer where the service tech warned me that my after-market metal valve stem caps were corroding the valve stems and TPMS sensors.
Basically, he said a couple of bucks at Wal-Mart for plastic caps will save me $200 per tire!
The previous owner of my CF put those metal ones on. I had no idea they weren't stock.
It also goes to show me that my MB dealership is looking out for me.
As a side note, MB also changed the oil grade from 0W-40 as well, not just Chrysler.
Old Jan 15, 2010 | 11:52 AM
texas t's Avatar
Talking Re: Beware Metal Valve-Stem Caps!
What did they change the oil too?
Old Jan 15, 2010 | 11:57 AM
mikenewb's Avatar
Default Re: Beware Metal Valve-Stem Caps!
Think mine are aluminum, so those be OK..
H82BL8's Avatar
Discount Tire told me the same thing. Go with plastic no worries.
Old Jan 15, 2010 | 12:24 PM
apkano's Avatar
Life is random...so am I.
Go with plastic.
The metal (either steel, stainless, or aluminum) will cause a chemical bond with the valve stem over time. Anytime you put dissimilar metals together you can expect a long term reaction, be it chemically "welded" or the opposite, corrosion. These negative effects are magnified by the fact that our valve stems are actually part of an electric sensor.......think electroplating, electrogalvanizing, etc.
Old Jan 15, 2010 | 12:34 PM
patpur's Avatar
Senior Member/Moderator
Here's the deal folks, yes they do corrode at some point but heres what I have done. I simply unscrew them when I wash the car, shot of silicone spray and put em back on. I've never had an issue but I do that regularly. Now that said my daughter took her Audi in for service at the Audi dealer and when the guy tried to remove hers he ripped the stem. They tried to charge her $100+ for a new stem and then told her by the way they all need to be replaced ($400+). NOT SO FAST! You simply heat the metal cap with a lighter or other device. We have a really neat little propane torch. After a few seconds wrap a towel around it so you don't burn your fingers and it will come off. This worked on the other three that had fused/ corroded on her car. Because there is no way she will ever do my fix we replaced hers with plastic caps like Apkano suggests. I've noticed that whenever a tire place fills a tire with Nitrogen they use these fancy little metal caps with a green tip or writing on them. You should check your caps.
Old Jan 15, 2010 | 12:41 PM
kaiser's Avatar
My son had same problem with his girlfriend,s Honda...Has sensor valve-stems as well..He told me about it so I checked the ones on my xfire and they looked like they were made of aluminum..I took each one off and sprayed with lithium grease..so far no problems...
Old Jan 15, 2010 | 06:12 PM
Chris L.'s Avatar
Last week was really cold & snowny in KC, my garage was about 35 F & my pressures were all about 32 psi. I decided to pump the tires up to 36 psi .... cause I was going to work an evening shift & there was a chance it was going to be about -10 F when I got off work. When I took the compressor off the last tire....the little core valve stuck "in".....try as I might I couldn't get it to pop back out.....till I sprayed WD-40 in there.....
Old Jan 16, 2010 | 07:05 AM
crossfirefun's Avatar
I have the steel ones on mine. I give them a turn off and on around once a month and haven't had any problems. My car doesn't go out in rain or snow though.
Old Jan 16, 2010 | 10:59 AM
Hawk Monster's Avatar
Is it by accident or did I noticed that all of you who wrote in were in areas of cold, damp and snowery winters. I agree it is to small a sample but I did notice a trend or don't you check the tire pressure frequently i.e. remove the valve caps.
Old Jan 16, 2010 | 05:39 PM
OKC-XFR's Avatar
I think the salt on the roads causes the dissimilar metal reaction and corrosion. I put aluminum caps from Wal-Mart on my Durango when I lived in NY. 3 or 4 months later (it was during the winter), I went to check the pressures and couldn't get any of them off. I was able to cut 2 of them off with a Dremel, but messed up the other 2 stems badly enough that I had to have them replaced.
I put metal caps on my Crossfire, but put some anti-sieze compound (get it at AutoZone) on all of the stems before putting them on. Now I turn them off and on every time I wash it and haven't had a problem yet.
Old Jan 16, 2010 | 06:29 PM
Bazzer's Avatar
I live in a cold and damp environment too and I too have metal valve caps. I check my tyre pressures weekly and have never suffered from seized caps.
Old Jan 24, 2010 | 11:27 AM
Veloce's Avatar
NYPD-Crossfire said,
texas t said,
Me,
What did they (Chrysler/MB) change it to?
Old Jan 24, 2010 | 07:20 PM
Originally Posted by NYPD-Crossfire
I just got back from my trusted MB dealer...
Union Centre or Montgomery Road?
Old Jan 24, 2010 | 07:57 PM
Veloce's Avatar
Default Re: Off Topic - Beware Metal Valve-Stem Caps
James 1549,
When I see that photo of your car I know why I love the design!
Old Jan 25, 2010 | 10:23 AM
patpur's Avatar
Just a reminder - If your caps seize try heating them with a lighter or a torch ( we have a small SnapOn torch for use in tight spaces). I was told my daughter's car would need 4 new stems and sensors. We got the other three off by heating them a bit, no problems. The dealer broke the 4th one. If you are taking your car in for service I'd suggest checking the valve caps before you drop the car off. All you need is a inexperienced tech to get a little heavy handed. By the way, my stock wheels came with metal caps, so did my daughter's Audi.
Old Jan 25, 2010 | 11:32 AM
Veloce's Avatar
Our green (Nitrogen) caps are plastic.
I also check the air pressure on a regular basis. I do this in the garage when the tires are cool and I've also invested in a small doughnut shaped air compressor to fill them as I check them--phooey to Nitrogen as it is too much trouble for such little/questionable benefit.
Old Jan 25, 2010 | 11:38 AM
patpur's Avatar
I agree with you on the Nitrogen. If it was the standard ok but its a PIA otherwise.
Pat
syfi
Mar 28, 2026 04:14 PM
55chevy
Jul 22, 2024 02:31 PM
4drturbo
21
Nov 12, 2018 04:50 PM
Darryl Camisa
Oct 7, 2015 07:10 AM
Billto
Sep 28, 2015 12:05 PM
