Another Problem
Old Feb 25, 2010 | 05:55 PM
askmenomore's Avatar
Default Another Problem
ok my car has brandnew battery and i did the rcm thing and still nothin when i turn the key. What do u think it is?
Old Feb 25, 2010 | 07:22 PM
Toolman's Avatar
Default Re: Another Problem
When you say nothing happens I expect you are saying the engine does not turn over "rotate" and there is no clicking noises. If you have an automatic transmission it's possilbe the Park/Neutral switch is broken or not fully engaged. Try shifting into park a couple of times. I would next look at the starter solenoid and starter.
Old Feb 25, 2010 | 07:26 PM
yea no turn over or nothin and its a 6speed
Old Feb 25, 2010 | 07:39 PM
Toolman's Avatar
I go for the simple most likely causes first. The clutch interlock switch could be broken or out of adjustment.
Old Feb 25, 2010 | 07:40 PM
magneticred's Avatar
Make sure the NEW battery is fully charged. Batteries can loose charge if they sit on a shelf long enough.
Old Feb 25, 2010 | 07:51 PM
Goldwing's Avatar
First, make sure your battery is fully charged. Trickle or battery charger.
Get a couple beefy neighbors. Promise them beer when the job is done. Have them push the car as fast as they can and then pop the clutch with the ignition on. This eliminates the starter and even a weak(er) battery. If it does not start, you may have a problem with your ignition. Or ECU. Or something.
Old Feb 25, 2010 | 08:05 PM
Toolman's Avatar
Do you own a volt meter and know how to use it? You would be able to measure if the battery is at 12 + Volts.
In addition, you can check most of the starter circuit by measure for voltage at the starter solenoid when the ignitiion switch is turned on. Put the + clip lead from the meter onto the small wire connector on the solenoid, and the negative lead to the chassie/ground of the car. When you push the clutch peddle in and turn the ignition key you should see 12 volts on the solenoid. If you do see 12 volts the problem is either the solenoid or starter. If you do not see 12V the problem is back in the starter circuit wiring. I would go back and check the clutch interlock switch.
If you do not have a meter you can remove both the battery and the starter and most auto part stores will test them for you.
Old Feb 25, 2010 | 08:58 PM
where is it and how do i adjust it
Old Feb 25, 2010 | 10:07 PM
Toolman's Avatar
The clutch interlock switch is attached to the bracket that the clutch pedal pivots on under the dash. It could be physically out of place or defective. You can visually check the operation while moving the pedal. You would need an ohm meter to check the switch contacts.
Old Feb 26, 2010 | 06:47 AM
apkano's Avatar
Life is random...so am I.
Start real simple......
Does ANYTHING work? Lights, radio, horn?
Old Feb 26, 2010 | 11:56 AM
yea everything works just no turn over
Old Feb 26, 2010 | 12:21 PM
downwardspiral's Avatar
I don't think that will work, but I know it works on older cars. The clutch pedal has to be down to start the car. The drivetrain will rotate to absorb the energy, but there will be no spark or fuel.
I think your best troubleshooting tool would be a multimeter. You can tap into switches, injector cables, sensors etc. and check for continuity through them. For example, tapping across a fuel injector. A fuel injector is basically just an electromagnet / normally open switch. If you are cranking the car, you should see voltage through an injector.
Old Feb 26, 2010 | 12:38 PM
ok i figured out what it is. The part on the clutch that pushes the pen down fell off i found it under my floor mat. but now i cant get the dash apart to fix it. how do i get it apart??
Old Feb 26, 2010 | 12:57 PM
Go to the shop manual, section 6, page 4 (2004 manual)
Old Feb 26, 2010 | 02:19 PM
i bought my car used and for some reason it didnt come with a manul
Old Feb 26, 2010 | 02:56 PM
Toolman's Avatar
A PDF copy of the service manual is in the SRT6 section of the forum. It's a sticky titled Crossfire SRT6 Documentation collection.
Old Feb 26, 2010 | 09:03 PM
Finaly got fix. thanks for all the help. what a pain one thing after another
Old Feb 28, 2010 | 10:12 PM
musicnsurf's Avatar
you should sell it and buy a honda civic.
Old Feb 28, 2010 | 11:03 PM
xodus52's Avatar
BLASPHEMER!!! where's my torch and pitchfork....
franklindm
Mar 14, 2020 12:23 PM
eikon
Sep 9, 2019 10:16 PM
Sterling57
Apr 11, 2016 06:11 PM
Steven 4190
Nov 25, 2015 10:12 AM
jimf
Oct 10, 2015 10:22 AM
