Major problem help!!!
Old Mar 15, 2010 | 11:43 AM
  #41 (permalink)
2005crossfire6speed's Avatar
Default Re: Major problem help!!!
Originally Posted by Chris L.
Congrats, you got lucky. By the way, what is the highest speed that you have ever downshifted into first? What RPM level did you rev-match?
The fastest I will down shift to 1st is about 10 usually i am in 2nd by 5 mph and go from there
  #42 (permalink)
Infinite's Avatar
well with a broken motor mount the engine/trans will move around under accel. this can cause the output shaft to flex and it will cause metal on metal contact and can also cause input/mainshaft misalignment which is why it would make noise in a certain gear, due to the torque multiplier of first gear.
Old Mar 15, 2010 | 11:48 AM
  #43 (permalink)
Our Cars have a split driveshaft. The carrier bearing worn or loose would cause this. If the motor mountrepair dosen't fix it, I wouldlook there.
Power shifting loads this part very seriously. Shifting up or down.
roadster with a stick
Old Mar 15, 2010 | 12:58 PM
  #44 (permalink)
Musclefan21's Avatar
Originally Posted by 2005crossfire6speed
I did and it wasn't. They just got done and said all it is is a broken engine mount and will cost around $250.
Doc called it! Glad it wasnt serious!!!
Old Mar 15, 2010 | 02:28 PM
  #45 (permalink)
Big Al's Avatar
Originally Posted by bmorgan
Sitting there for 2 hours!!! Must be like waiting at a hospital with a loved one in surgery waiting for the doc to come out and give you the news.
"AMEN BROTHER"
Old Mar 15, 2010 | 03:50 PM
  #46 (permalink)
Fred's Lifetime Powertrain Warranty is looking better & better.....
I do not believe anything would be covered by the PT warranty, especially with evidence of (possible) abuse....
Originally Posted by Big Al
Never start out from stop in any gear higher than 1st, you will only ruin what is left of your clutch. You said it does well when you take off slowly in first gear, well, TAKE OF SLOWLY". But take off in 1st only.
Why do you say this? Is it because of his issue, or would you say no one should ever start out in second? Please explain further.
Originally Posted by Vegaslegal
My two cents. Second gear is no different than first in a 60s 3 speed. My guess is that the materials are even better today. Shouldn't hurt anything as long as done well.
I always start in second, unless on a hill or really trying to take off. The start is much smoother and none of that 1 --> 2 harshness. In winter, this method helps out quite a bit in slick conditions, in fact, I believe the W on the shifter on the autos is winter mode where the car actually starts in second for this exact reason.
Old Mar 15, 2010 | 04:25 PM
  #47 (permalink)
first gear is there for a reason. 2nd gear is a bit hard on the clutch. I will always use the first gear to take off unless the roads are icy or i am facing down on a hill.
Old Mar 15, 2010 | 06:38 PM
  #48 (permalink)
Chris L.'s Avatar
If I'm only intending to smoothly move away from a stop.....I frequently start out in 2nd.....there's just absolutely no slippage in these circumstances with the 6 spd Crossfire...no strain.....nothing. You would never do it if there was any desire to accelerate briskly. It's especially useful in parking lots where 1st gear might kill a pedestrian...
Old Mar 16, 2010 | 08:43 AM
  #49 (permalink)
I agree 1st is there for a reason, exactly as I stated, when I am on a hill or trying to really take off. As Chris stated, there is no additional strain on the clutch, as usually I do not even apply gas to the car to get it rolling and I NEVER have an issue starting, never a funny smell, and never a jerky start. I fail to see why there is anythign wrong with this logic.
Unless there is a transmission tech or someone else out there with serious expertise with THIS car that tells me otherwise, I will continue my practice. (with other cars, I have never tried this, just found it to be most convenient and less stressful on the X than 1st starts)
Old Mar 16, 2010 | 11:26 AM
  #50 (permalink)
Infinite's Avatar
I beat first gear like it owes me money
Old Mar 16, 2010 | 11:45 AM
  #51 (permalink)
32krazy!'s Avatar
if you have 1 broken motor mount the other is likely worn and the tranny mount as well. spend the money now and replace all 3. if not you will be paying labor all over again to do this repair down the road. just my .02
with over 2 million miles driving everything from a 7 speed to a 21 speed triple stick mack i know a bit about shifting. the closeness of the gear is what allows you to start in the higher gears without slipping the clutch
with the xfire 6 speed it wouldnt be advisable to start in 2nd on a regular basis. use 1 to get rolling then shift. again my .02
Old Apr 28, 2010 | 01:04 AM
  #52 (permalink)
omar cisneros's Avatar
i had a similar problem in my automatic crossfire, i remplace the 3 motor mounts because they were broken, and the grinding sound disappeared, i donīt kwon the sound was coming from mount, i thing the sound was from the moffler or something like that, but no, the sound is relationated with the motor mounts.
Old Apr 28, 2010 | 07:56 AM
  #53 (permalink)
Ed Mahoney's Avatar
I would stay away from dealership take it to a good transmisson & clutch place !! Call & check around will be a lot cheaper !!!!!
Valk
Jun 22, 2025 09:15 PM
tcar32909
Aug 1, 2024 02:41 PM
nataliefs
Oct 5, 2015 01:03 PM
Den656
Sep 23, 2015 12:27 PM
skeet370
29
Sep 18, 2015 05:53 AM
