Car almosts stalls coming to a stop sign/redlight
Old May 4, 2010 | 03:10 PM
donschorr's Avatar
Default Car almosts stalls coming to a stop sign/redlight
I have an 05 with 29K miles, automatic tranny, no mods.
It just started doing today, deaccelarate to stop sign- and the car almost cut off, I nursed the gas pedal it came back to normal RPM's- it happened three times today, first time ever happened. No check engine lights.
Twice when I accelarated the power didn't seem smooth.
Thanks for any suggestions.
Don
Old May 4, 2010 | 04:18 PM
Blast Chamber's Avatar
Default Re: Car almosts stalls coming to a stop sign/redlight
Did you recently fill up at a gas station? If so, you may have got a bad tank of gas either with water in it or debris that has plugged up the fuel filter.
Old May 4, 2010 | 04:24 PM
waldig's Avatar
Talking Re: Car almosts stalls coming to a stop sign/redlight
Could be a vacuum leak, easy to check by getting a simple gauge and some hose to reach the engine thru the window. Get a youngster to listen to the idle and see if they hear a vacuum leak is an alternate, they still have the high freq hearing that fades with cars and age..........Woody
Old May 6, 2010 | 07:42 AM
donschorr's Avatar
Gas purchased from the same BP station as always- they check their tanks weekly for water- tanks installed 5 yrs ago.
Thanks for your suggestion, I would change out the fuel filter as a last resort- but I don't think it is the culprit.
Old May 6, 2010 | 07:44 AM
donschorr's Avatar
Checked no vacuum leak.
Thanks for your suggestion.
I still am having the problem- drove yesterday about 10 miles, slight hesitation after warming up, the car's RPM's did not crash down like it did when I drove it over 100 miles on Monday.
Old May 6, 2010 | 07:59 AM
apkano's Avatar
Life is random...so am I.
Pull the negative battery cable for 1/2 hour and then reattach. You're basically resetting the learned history in the PCM.
I had the same problem once at about 50xxx miles only when I exited the expressway......it hasn't come back.
Old May 6, 2010 | 09:29 AM
donschorr's Avatar
I recently reset it inside the car.............
but
I just pulled the neg cable and cleaned the positive cable/post- had a little build up not much IMHO.
I will try to see if doing the negative cable helps.
Don
Old May 6, 2010 | 10:37 AM
former NXMX5's Avatar
with 30K miles, you should have changed the fuel filter once already...
Old May 6, 2010 | 11:16 AM
apkano's Avatar
but
Don
Pulling the battery cable for 1/2 hour will reset the PCM (powertrain control module)....... you usually reset the FSS (flexible service schedule) from inside the car.
Old May 6, 2010 | 11:19 AM
Unless he is talking about resetting the PCM with the key+gas pedal trick from inside the car
Old May 6, 2010 | 11:33 AM
donschorr's Avatar
That is what I was talking about.
Don
Old May 6, 2010 | 11:34 AM
Ed Mahoney's Avatar
I would say its time to change fuel filter too !!!! 05 with 29,000 !!! Why not ?????
Old May 6, 2010 | 12:26 PM
donschorr's Avatar
This would be the quickest fuel filter change in over 30 cars I have owned- I know where I buy my gas- where are you getting it is time to change the fuel filter? It may be the problem, I don't know- but with less than 30K miles and knowing where I purchase the gas from,,,,,
Thanks for your help and I know you are only trying to advise the correct things to do.
Don
Old May 6, 2010 | 02:13 PM
apkano's Avatar
That works excellent for resetting the drive-by-wire / throttle. It does absolutely nothing for resetting the PCM though.
Old May 6, 2010 | 02:15 PM
donschorr's Avatar
Thanks for clearing that up for me Apkano- I didn't know there was a difference-
does taking off the negative cable also reset the drive by wire throttle and the PCM?
Thanks
Don
Old May 6, 2010 | 02:16 PM
Don
You also buy highly-regarded Mobil1 oil, but still change it and your oil filter every 7,500 miles right?
Old May 6, 2010 | 02:17 PM
donschorr's Avatar
Yes- on the oil and oil filter.
Old May 6, 2010 | 07:35 PM
donschorr's Avatar
Apkano-after resetting the PCM, I was so happy............ drove for about 15 miles had my old Xfire back-
however getting near my home, the stutter happened again, not as bad as before but still very evident to me, I was bummed again.
Thanks for your suggestion and I was hoping to offer a dinner on me, for the suggestion. Any other ideas besides the fuel filter, which may be my next try?
Don
Old May 6, 2010 | 08:34 PM
Does the car still have the original OEM battery? If so, it is 6 years old, and there have been cases of older batteries with lower voltage causing weird symptoms in the Mercedes electronic systems.
I realize this is thin and is just a WAG on my part, but if you are soon due for a new battery anyway it may be worth a try. I'll be replacing my OEM battery next week even though I'm currently having no problems.
Old May 6, 2010 | 08:52 PM
donschorr's Avatar
Battery has not been replaced but had my mech check it out- tested fine- do you think it could cause a problem when it tests OK?
Thanks
Don
