DRB III and Fuel Filter Change
After reading the service manual on changing the fuel filter- it says you may need to reset a code using the DRB III after pulling the fuse on the fuel pump to take pressure off of the fuel line.
My mechanic doesn't have a DRB III, and said I would probably have to take it back to Chrysler to reset the code.
Anyway/thing that can be done to avoid the charge to reset the code at the dealership?
Thanks
Don
Thanks
Don
Re: DRB III- and Fuel Filter Change
Thanks
Don
Thanks
Don
on
Re: DRB III and Fuel Filter Change
Originally Posted by former NXMX5
ive changed the fuel filter 5 times and never removed the fuse... never reset the system with the DRB tool.
just cap the hoses as you remove them so they wont leak.
Thanks
Don
on
What did you cap the hoses with? and how much fuel leaked?
Thanks
Don
Thanks
Don
we have an assortment of plastic caps in the garage; they usually come as protective covers on new fittings. Youll get some with your new filter (to start your own collection!).
Thanks for your help.
Don
Thanks!
I am getting to the point of needing to change this myself, but can I ask why you have had to do this 5 times? What is the mileage/timeframe the manual calls for?
Thanks!
Thanks!
on
I changed the battery about 2 weeks ago and have driven the car about 200 miles- it is not the battery that is causing the hesitation/stutter in the RPM's. It still is doing the stutter at stops- as long as I am moving I do not notice anything wrong. Come to a stop and the hesitation/stutter is there often dropping the RPM's to around 500 or a little lower before coming back up, it has never shut down- Yet.
I will try to get the fuel filter changed this week.
Don
Don
Don
Don
Don
Don
Come to a couple stop signs and the RPM's falter before recovering back up, slight hesitation on take off.
What is still wrong in the boards opinion.
Thanks
Don
I got the fuel filter change accomplished finally- went for a hundred mile spirited run through the mountains, lots of twistys nice run.
Thanks
Don
Thanks
Don
Check your plugs and leads. How many miles has your car done? I change mine every 70,000 km just to keep everything top notch. Needswings will help you out in that department. Fuel filters are not too high of a maintenance item changing it every 30-40,000 miles will keep you sweet.
Originally Posted by Style
Could be a number of things Don. Guys with more mechanical knowledge than I could probably offer a few more suggestions but consider this. Our cars do naturally have a rather 'lumpy' idle. Still by what you've said yours does seem more pronounced. Clean the injectors. You can get stuff to flush 'em out or you can go and get them taken out and cleaned professionally (lol why not upgrade while you got everything apart). Do you run premium fuel?
Thanks
Don
Thanks
Don
The dealership mechanic and service writer who I have become friends with both state that the Xfire has minimal problems with it except for the common things we all discuss- however this was the first on the cracked hose.
Good luck- if it turns out that the hose did not take care of my issue I will let the board know.
Crossfireone
23
08-25-2015 04:56 AM
07-24-2015 07:57 PM
