Little Rought Idle
Old Dec 31, 2010 | 09:19 PM
maxime75us's Avatar
Default Little Rought Idle
Hi All,
I have a little rough idle
When I am in park, I can feel every 5 or 10 seconds a little bump"""
Always trying to get my girl happy ( my car) so if I could resolve the problem it would be great...
Thanks all
Happy New Year 2011!!!!!!!!!
Old Jan 2, 2011 | 10:08 AM
Cody M's Avatar
Default Re: Little Rought Idle
What does your RPM's show? Should be sitting at about 800-900 RPM sitting in park.
Old Jan 2, 2011 | 11:09 AM
maxime75us's Avatar
Hi,
Thanks for your help.
It is around 700 to 800 rpm
In some occassion goes down to 500rpm but I can notice a little bum every 5 or 10 seconds...
Any idea?
Thanks again
Old Jan 2, 2011 | 03:47 PM
Cody M's Avatar
Do you notice your RPM's moving up or down during this noise? If at all possible take a video from inside your car so we can hear the sound it's making. You said your having a rough idle. The first thing that I would check would be a loose vacuum hose somewhere. Second, how many miles are on the car? It could use some new plugs and wires. The car is most likely having a misfire somewhere and I would suspect a tune up is in order if your above 60,000 miles.
Old Jan 2, 2011 | 06:59 PM
Mr. Max's Avatar
Might want to clean the throttle body. A little ridge of crud builds up where the butterfly meets the bore. Be sure to use the newer "plastic safe" stuff. Do NOT use the old fashioned carb. cleaner. You probably know this, but better said then omitted.
rfourt
Aug 12, 2020 07:27 PM
minimayhem
17
Jan 19, 2016 02:10 PM
massanu
18
Nov 23, 2015 08:52 AM
blackpepper
Racing
16
Sep 27, 2015 01:38 AM
Arm_and_a_Leg
Aug 14, 2015 12:25 PM
