Radio static when i turn headlights on
Old Jan 21, 2011 | 07:23 PM
texpitt's Avatar
Default Radio static when i turn headlights on
When i turn on my headlights i get static on the radio, is there a fix for this.
Old Jan 21, 2011 | 07:39 PM
MI1XFIRE's Avatar
Default Re: Radio static when i turn headlights on
I would be willing to bet you have aftermarket HID.
Old Jan 21, 2011 | 08:16 PM
texpitt's Avatar
any ideas what i need to do, i do have a factory chrysler am/fm cd player radio, should i replace which i dont want to do because i want to keep my car original but if i have to get a new radio what kind of radio.
Old Jan 21, 2011 | 09:15 PM
MI1XFIRE's Avatar
If you have aftermarket HID headlights and want to keep the original radio, You're going to need to go back to the factory H7 headlight bulbs or find a better quality HID ballast.
Old Jan 24, 2011 | 04:14 PM
Goldwing's Avatar
If you have stock headlights and the radio only acts up when you turn on the headlights, then something is causing electrical interference. In the good old days, a static suppression gizmo could be placed on the coil wire to eliminate the problem, but there are six coils on these babies and no wires. You might want to try an store that installs custom auto sound systems (not a big box store) and they may have a suggestion. My guess is that replacing the stock radio may not eliminate the problem if something is causing electical interference. I assume with the engine off and radio on, it is perfectly clear? That's not a radio issue.
Old Jan 24, 2011 | 04:21 PM
I'd be willing to bet money that you are right.
But I think he missed your post.
There is nothing in a halogen bulb that would make RF, unless you have a really bad/dirty connection and it's arcing. Given the type of sockets in our headlamps, I don't think that is likely. I wonder if you could put bypass caps on the Ballast or an RF choke on it's leads?
I mean, sure you COULD, but it probably would not be very effective.
Old Jan 28, 2011 | 05:31 PM
bri3d's Avatar
When I got my Blaupunkt it actually made my grounding issues worse, so don't go running off to buy a new stereo. Mine are vehicle-related, though, since I can hear both my coils and especially my air injection pump loud and clear through the stereo.
If you've got HIDs, make sure the ballasts are secured firmly to a ground (bare metal), and try wrapping the ballasts in foil and putting ferrite rings (they're the goofy bulges in many computer cables - the kind you want will just pop off the cable and you can pop them back on) to your +/- ballast cables.
Chances are, though, you'll need higher-quality HID ballasts.
Old Jan 28, 2011 | 07:21 PM
Having a Steelers logo as your avatar and living in Texas could be the reason.
PNA
Nov 12, 2020 04:44 PM
Danyuhl
Nov 2, 2019 05:18 PM
wannaGOFAST
South Forum
Aug 14, 2015 01:20 AM
pioneer4x4
Jul 27, 2015 02:04 PM
xzmilan
Jul 22, 2015 10:40 AM
